Tranny Cooler-Trimatic
#1 _lxtorrie_
Posted 01 May 2006 - 10:11 AM
Has been a while since I have been on these forums. For some reason I cannot access this site from home aymore.
But anyways, I am waiting for the arrival of my new trimatic (stage 2 shift kit, custom valve body, v8 clutch packs & internals, billet servo, etc) to go with my megashifter and have purchased a tranny cooler out of a commonwhore from the wreckers. Its a small alloy cooler thats a little larger than my hands put together- it was only $20 and figure they do the job, even tho u 'can' buy bigger, i think this size is fine.
So....now I have to install it.
Can someone please tell me which way does the fluid flow through the trimatic, as in, which way does the fluid flow to the radiator? This is because I am thinking about going Tranny->Radiator->Cooler->Tranny.
Therefore I dont want to install the lines arse about and go tranny->cooler->radiator->tranny as the cooling will not be as efficient.
LXTORRIE
#2 _MRNOS_
Posted 01 May 2006 - 10:26 AM
#3 _lxtorrie_
Posted 01 May 2006 - 10:58 AM
Thanks for the reply. I was under the impression that a tranny does need to run a little 'hot', and that too much cooling can be just as bad as not enough. Hence why they used poxy radiator coolers on the old holdens, but mebbe im wrong.
I also figured an alloy tranny cooler from a 2000 model car would have been sufficient, and cool a whole heap more than the copper radiator style cooler, as the alloy style is far more efficient, but after reading your post I might have a look into something else.
I will have a look at larger coolers 2day, but I have an issue of space as there is not that much room left in the engine bay with sufficient air flow for a massive tranny cooler. I have EFI fitted, a 3 core cross flow radiator that takes up the whole front end, & not to mention the airbox crammed up the front also. Already have to run a set of thermo's due to not enough room between engine and radiator.
Edited by lxtorrie, 01 May 2006 - 11:12 AM.
#4 _MRNOS_
Posted 01 May 2006 - 11:02 AM
#5 _TORANR AMORE_
Posted 01 May 2006 - 11:07 AM
Stall converters cause heat, so if you have one, you'll need the tranny cooler. A secondhand one might be ok as long as you flush it. Also if your transmission is new, you should put a transmission fluid filter on the return line from the cooler to keep your transmission healthy, you can buy these for less than $50 and they are reccomended regardless.
#6 _lxtorrie_
Posted 01 May 2006 - 11:14 AM
Still need to know which way the fluid flows tho...so I know where to put the filter.
LXTORRIE
Edited by lxtorrie, 01 May 2006 - 11:17 AM.
#7 _MRNOS_
Posted 01 May 2006 - 11:15 AM
#8 _Lostit_
Posted 01 May 2006 - 07:04 PM
The bigger the cooler the better..
#9 _TORANR AMORE_
Posted 01 May 2006 - 07:57 PM
If you do it this way, then after turning the engione off connect that line to the cooler and with the other end open (with a hose pointing away from the car), pour more fluid into the auto from the top via the dip stick hole and then start the engine again and give it a few revs. This is the backyard way of flushing the cooler of any dirt or crap.
Then connect the filter to the short hose that was open, this will be the return line and connected.
Use 2 clamps for each connection. It will be under high pressure. You don't want fluid pissing out as it will eat your paint and the car will be very upset.
Posted 01 May 2006 - 11:51 PM
I'm all for you additional cooler mounted in the return line..after all you are not driving it in the mundane fashion it was designed for.
#11 _devilsadvocate_
Posted 02 May 2006 - 11:15 AM
Re using the radiator cooler and auxilary cooler. Not sure if this is a good idea, there may be two much restriction which could slow down the flow of coolant and get less cooling. Possibly suggest that it would be better to connect them in parallel.
Re
Why you have come to the conclusion? It may be correct, figuring that the radiator, possibly at 90C+ at the bottom when tranny cooling is critical will be better served to remove heat from the much hotter fluid as it first exits etc, than trying to remove heat from cooler fluid that has already gone through the cooler...however, there might be other things to consider there.Therefore I dont want to install the lines arse about and go tranny->cooler->radiator->tranny as the cooling will not be as efficient.
I have a lot of "not sures" here. Suggest that you do contact several tranny places and get their reccommendations. One has to weigh up, whether they are just passing on current/past industry practice that may be flawed or have actually done tests on stuff they have fitted and measured tempss of the fluid etc.
Fast EH has a good pt, the tranny fluid does need to get up to temp, AFAIK, no system of thermostats are fitted to tranny cooler systems. Perhaps fit a tranny temp sensor and gauge and use a blind during winter to block of part of the cooler to get the fluid up to temp
Edited by devilsadvocate, 02 May 2006 - 11:20 AM.
Posted 02 May 2006 - 12:25 PM
#13 _lxtorrie_
Posted 02 May 2006 - 12:45 PM
I will see how my new tranny cooler goes with filter, and check the fluid to see if it has changed colour.
If anything I may put another cooler in if I feel that 1 is not cooling enough.
I looked on www.vpw.com.au and some of the B&M, etc coolers they have available are much smaller in size than the one I have.
LXTORRIE
Edited by lxtorrie, 02 May 2006 - 12:46 PM.
#14 _devilsadvocate_
Posted 02 May 2006 - 01:19 PM
Don't see how that would be the case fastEH, the temp at the bottom of the rad is going to be at ambient til the the engine thermostat opens and in cold conditions(cruising at 60kmh at 10C) the temp at the bottom of the rad wouldn't exceed 40C in most setups. The radiator would still be removing heat from the fluid in all conditions.I firmly beleive you need to keep the radiator in the circuit to allow it to warm up quicker.
Point taken re not equal/optimum flow in parallel, however, but this could be adjusted(if a problem) by restricting the inlets on one of the devices.
In terms of optimum cooling having two devices in parallel is much more effective, and would be the best way to optimise using the radiator cooler if absolutely necessary. Of the opinion however, that if you fit an auxilary cooler, to just go with one big enough to to do the job, and not have to concern oneselves with the rad/trans cooler at all, by the time you buy the extra connecting fittings, it will probably cost just as much as the extra sized cooler.
Edited by devilsadvocate, 02 May 2006 - 01:33 PM.
Posted 02 May 2006 - 02:56 PM
#16 _Torana482HP_
Posted 02 May 2006 - 07:16 PM
i suggest just putting up with a sluggish tranny when you first start your car and install the tranny cooler in front of your radiator and only run the fluid through the tranny cooler.
The ideal operating temperature for auto fluid is between 79*C - 107*C. Anything other than light duty use will raise fluid temperature beyond this.
A commonly used statistic is that every 11*C rise in fluid temperature above the ideal operating temperature reduces fluid and transmission life by half.
When auto fluid reaches 121*C, varnish begins to form - additives are literally cooked out of the fluid.
As fluid temperature reaches to about 135*C, polyacrylate seals begin to harden. Consequently, they lose their elasticity, and leaks - internal and external - occur.
And at about 149*C, fluid can degenerate to the point where clutches slip. This, in turn, generates additional heat that breaks down the fluid further, resulting in massive transmission failure.
I wouldnt risk overheating your tranny.
just curious, were the biggest B&M coolers bigger than yours, as thats what i was gonna buy?
Edited by Torana482HP, 02 May 2006 - 07:30 PM.
#17 _lj chev_
Posted 03 May 2006 - 05:38 PM
why would you be cheap and by a $20 buck cooler for a 1 - 2 grand trans? new ones are $100 bucks onwards. its cheap insurance.
also i think you will find the pressure line is the fitting closest to bellhousing and return is closest to extention housing.
#18 _lxtorrie_
Posted 08 May 2006 - 09:15 PM
BTW The B&M coolers can be found on www.vpw.coma.au
Check under supercooler in the tranny cooler section.
The b&m range is 11 x 5, 11x6, 11x8 and 11x7.5 if im not mistaken.
My $20- one is in good nick, has been cleaned out and the fins are fine, not bent or broken. Also my radiator is a new crossflow.
Thanks for the reply's, but I dont see why how a b&m 11"x8" for approx. $127 would be that much better than the one I have as they both look almost identical in design except for the bracket positioning. As the one I have has both a bracket on the bottom (same as b&m) and a small bracket on top.
hmmm.......decisions, decisions.
LXTORRIE
Posted 08 May 2006 - 10:44 PM
he found that just by using redline synthetic trans fluid he DROPPED 60 degreed C from the trans temp.. compared to the same driving style etc with normal DexIII oil..
Oil's aint oils.. but at $250 ( as opposed to $40 for dexIII) to fill your trans with synthetic.. youve gotto ask if 60 degrees is worth it! ( I did it... I reckon its saved me a couple of times too!)
