Gidday,
I have just cut out the drivers side floor pan in my LH to replace(some rust holes against the tunnel) and noticed a slight rusty apperance to the inside of the chassis rails and a smaller sub frame? type part which runs at 90 degress to the chassis rail up the front area.
My query is do I clean the inside of these up with a wire wheel or similar and then use rust converter or fish oil or just primer or what before replacing the pan?
Should I not use fish oil anywhere until after the car is totally resrayed?
Thanks Rod.
Fish Oil query
racean69
, May 01 2006 09:39 PM
6 replies to this topic
Posted 01 May 2006 - 09:39 PM
#2 _ChiaLX_
Posted 01 May 2006 - 09:50 PM
You should be able to paint over rust converter but not fish oil. Another trick is to use peanut oil as it does'nt smeel so bad
Edited by ChiaLX, 01 May 2006 - 09:51 PM.
#3 _1QUICK LJ_
Posted 01 May 2006 - 11:25 PM
wire wheel it then treat it with ranex or deoxodine then do the welding get car painted then fish oil.
Posted 02 May 2006 - 03:04 PM
rainex is bloody good. that reminds me, my doors are due for their coupla monthly fish oiling again.
Posted 02 May 2006 - 06:41 PM
Thanks for the reply's.
I will be onto it.
cheers Rod
I will be onto it.
cheers Rod
#6 _Bomber Watson_
Posted 06 May 2006 - 01:09 PM
tectyl. works just as well and smells a lot nicer.
#7 _Bomber Watson_
Posted 06 May 2006 - 01:12 PM
