front end
#1 _Nic_
Posted 03 October 2010 - 11:40 PM
Posted 04 October 2010 - 12:02 AM
#3 _Nic_
Posted 04 October 2010 - 09:42 PM
any help would be great thanks
Posted 04 October 2010 - 09:59 PM
Maybe some pics of what you mean.. showing engine bay and mounts and block brackets
#5 _Nic_
Posted 04 October 2010 - 10:48 PM
thanks
Posted 04 October 2010 - 11:57 PM
#7 _Quagmire_
Posted 05 October 2010 - 08:28 PM
Hi thanks for replying, the engine did come out of an lx but is going into a different lx and it doesnt fit into the cross member of my new lx. its like the cross member mounts need to be slightly higher up on the cross member 15mm on each side to match the width of the engine mounts attached to the block. i an unable to take photos before the weekend so can not show photos at this stage sorry, hope this helps
thanks
what came out of the car you trying to put it in?
a 253/308 will fit anywhere a 202 or red motored 6 etc fits as the mounts on the body are the same
you either have a opel subframe or it has been moddified to fit a vn motor or something
#8 _Nic_
Posted 05 October 2010 - 09:16 PM
What does the frame in the donar car measure?
Hi it measures 44cm from the holes on the cross member and the v8 with mounts on measures 47cm (mounting holes) i have tried forcing it down but can not compress the mounts up enough to drop into position.
Posted 05 October 2010 - 09:28 PM
#10 _Nic_
Posted 05 October 2010 - 09:31 PM
thanks
Hi, according to my rego papers it had a 202 in it . the motor i got came out of a lx and is a 308 i have kept the engine mounts on the 308 so i thought it should just drop in but i can not get it in, to fit into position i am 30mm wider than the cross member mounts i have tried one side at the time and both sides at once but can not force it into the frame. that is why i was questioning if there is a v8 cross member as some one had told me i would have to get a v8 cross member and i thought they were all the same.
Posted 05 October 2010 - 09:34 PM
I would advise getting the correct x member if this is the case.
Posted 06 October 2010 - 12:33 AM
Pics...........
#13 _robslxhatch_
Posted 06 October 2010 - 04:48 PM
#14 _Quagmire_
Posted 06 October 2010 - 05:01 PM
showing what your looking for
#15 _Nic_
Posted 06 October 2010 - 10:58 PM
#16 _robslxhatch_
Posted 15 October 2010 - 06:11 AM
Hi thanks for that i will check tomorrow and see if i have them the right way around and hope its that simple to fix the problem will keep you posted cheers!
did you find the problem??
#17 _Nic_
Posted 15 October 2010 - 11:21 AM
#18 _robslxhatch_
Posted 15 October 2010 - 12:35 PM
Hi yes i did thanks, the engine is now in, we had the engine mounts up side down couldnt beleive thats all it was. i guess this happens when you are under a lot of presure to get it finished on time. any way i now have 4 days left that i can work on this car to finish it for a car show over here at the end of the month so its going to be really close i can see some really late nights coming up!!!!
i thought so , i did that once myself .I know whats its like to have no free time , my Torana is supposed to be finished last April. haha.
