Edited by brett_32i, 02 May 2006 - 06:57 PM.
changing tacho from 4 to 6 cylinder
#1 _brett_32i_
Posted 02 May 2006 - 06:56 PM
#2 _WYLDLC 6_
Posted 02 May 2006 - 07:07 PM
#3 _tj81_
#4 _devilsadvocate_
Posted 02 May 2006 - 07:13 PM
Posted 02 May 2006 - 11:09 PM
"Well i can help you out with this one as i had the same troubles with mine
1st- do u have standard ignition or electronic??
IF STANDARD
Go to dicksmith or any electrical store
ask one of the assistance for a 100k POTENTIOMETER
then what u do is where ur tacho connects to the coil follow this back inside the car and cut that wire then strip the plastic back and solder the potentiometer onto 1 outer pin and the other wire onto the middle pin
now start the car ur tacho pin WILL bounce now u get ur motor revving to 1000rpm then with a screwdriver turn the potentiometer until it sits on the spot
IT MAY NOT SIT ABSOLUTLEY PERFECT BUT ITS ACCURATE"
Edited by rodomo, 02 May 2006 - 11:10 PM.
#6 _brett_32i_
Posted 03 May 2006 - 09:44 PM
it sounds from his description, that by adjusting the pot, you minimise the 'bounce'.
so the needle will always be moving +/- the same value, and you just zone in to achieve as little bounce as possible???
Posted 04 May 2006 - 03:15 PM
#8 _brett_32i_
Posted 08 May 2006 - 07:30 PM
get the 10k pot, multi turn for better accuracy.
solder it across the 2 terminals of the needle coil.
what it does is lower the voltage to the needle coil, and therefore you can wind the pot to match the new tacho to a known tacho.
i'm just knocking up a square wave generator, so i'll keep you posted....
Posted 08 May 2006 - 08:23 PM
For the reference:if its on an SLR guage, there is a switch on the back, i know for 6 and 8, i cant remember if there is a 4 cyl option.....
Yes, there is also a 4cyl option. But early SL/R Guages (With MPH listed also) there is no option at all; V8s only.
#10 _devilsadvocate_
Posted 09 May 2006 - 11:08 AM
It wont have a smoothed output, but should be fully rectified giving 100 12V pulses per second.
Connect the tacho in the normal way to the 12V car system, but use the +ve of the battery charger as the input rather than the -ve from the coil, connect the -ve of the battery charger to the body of the car.
100pulses per sec = 6000/min
If its a six there are 3 pulses per rev.
6000/3 = 2000rpm
hope i got that right!
