Posted 23 October 2010 - 04:48 PM
frOck sodablasting, i cannot think of a single reason why you would want to use it.
OK, sure, you can leave your windscreen in and it wont damage the screen or rubbers, but most the rust on old Holdens is around the screens so WHY THE frOck WOULD YOU LEAVE THE SCREEN IN DURING A FULL RESPRAY???
And im assuming that because your talking about taking it right back its a full respray.
Get it sand blasted, cheaper, will remove bog and ALL rust, and it doesnt leave a stupid film.
Where your mate got the idea from is that sodablasting leaves a film that will stop the bare metal from rusting, but if you paint over it the paint will peel strait off. You need to use soapy water to take this film off, then you have soapy water on raw steel, wala, instarust.
Also i have no frOcking idea how you get your soapy water in and out of the small crevices etc.
Now im sure you have heard some horror stories about sand blasting, and yes if done wrong it will totally frOck the car.
Cruise around, get a few quotes, theres usually several sandblasting mobs in any area.
Make sure you talk to the person who will be doing the blasting.
If they dont seem overly intersted, move on, if they go "hey, a Torana, cool" then use that person.
You Have to realize that most of these guys deal with mining companies who pay 10's of thousands of dollars to get stuff done, you rocking up with a little car shell that they will make frOck all out of wont interest most operators, you need to find the one that is into old cars, respects old cars and wants to do the job.
If you give the car to an uninterested party, you will get back a twisted mangled wreck, if you give it to an interested party, then you will get back a car that is totally clean, free from any rust/bog/etc within reason (impossible to blast inside a sill panel for instance, you will have to remove the sills if you want in there done, as an example)
Also, as said, for the same finish soda will be more expensive. So when you find an interested party offer them the same amount as your quote for soda blasting, that should put a smile on there face. Hey, you were gonna spend that much anyway, the extra $$$ will insure they do a micky mouse job.
The surface you will receive is ready for a thorough blow down and then primer, thats it, no frOcking around. Most places will also prime it for you for a small extra cost. Your choice of primer. I'd go a zink phosphate based epoxy personally.
Hope this helps a bit. Oh BTW im a sandblaster/spraypainter working on gear that works in highly corrosive environments and high selenity water, so yeah, i have a rough idea what im ranting about.
