Factory Alignment specs
Posted 04 May 2006 - 08:59 PM
getting back into my playing with front ends and steering.
Can anyone help me out with the following:-
1. The factory camber, caster and toe-in for each of the models above?
2.What diameter front tires they had on them
and here is the tricky one
3. The height from the ground to the front subframe on a standard height car?
(I found the height to the centre of the steering rack bolt to be the easiest to measure on mine)
Posted 11 May 2006 - 08:23 PM
I'm doing the hard bit - how about getting those books out and giving me some specs?
M@
I even found the answer to number 2 in another thread last night.
_CHOPPER_
Posted 12 May 2006 - 11:08 PM
LH alignment settings:
Castor: -1 degree +/- 1 degree
Camber: + 0.25 degree +/- 0.75 degree
Toe: zero +/- 1/8"
L34 alignment settings:
Castor: -0.5 degree +/- 1.5 degree
Camber: -0.25 degree +/- 0.75 degree
Toe: zero +/- 1/8"
A9X alignment settings:
Castor: +1 degree +/- 0.5 degree
Camber: -1 degree +/- 0.5 degree
Toe: 3/16" +/- 1/16"
Couldn't find Pre RTS and post RTS LX, but from memory both are the same as LH.
Posted 14 May 2006 - 06:16 PM
Do you know the UC ones as well??
M@
_CHOPPER_
Posted 14 May 2006 - 09:05 PM
Posted 15 May 2006 - 02:39 PM
_CHOPPER_
Posted 15 May 2006 - 06:50 PM
Castor: +0.5
Camber: -1 ( if possible )
Toe-in: 2.5 MM
Due to the HQ stubs and lowered springs, it may not be possible to adjust it up to -1 camber. I have seen vehicles with all shims removed and still having -3 camber. To go from -3 to -1, shims ned to be removed.
Posted 17 May 2006 - 03:30 PM
Posted 17 May 2006 - 08:17 PM
Caster, 1 to 3 degrees positive
camber, -2 to zero
toe in, 0 to 0.95 mm positive
Good work on this Toranamat. I suspect I'll be using your findings at some stage
_CHOPPER_
Posted 17 May 2006 - 09:24 PM
_munro_
Posted 16 June 2006 - 04:40 PM
if you run -2deg camber you will scrub the insides of your tyresIf you want to believe a Gregory's manual, specs for UC are;
camber, -2 to zero
try and get it to -0.5 - -1deg at the most
cheers tom
_Torana482HP_
Posted 16 June 2006 - 05:45 PM
