I was just wondering how i should go about painting the center strip of an LC grille?
Should i get paint mixed that doesnt require a primer or buy some 1k and perhaps prime from a spray can?
Its only a small section so if the results are crap I can manually cut and polish it.
Painting LC Grille center strip
smeer
, May 06 2006 01:02 AM
4 replies to this topic
Posted 06 May 2006 - 01:02 AM
#2 _pipjones_
Posted 06 May 2006 - 07:13 AM
VHT make a Satin black chip resistant paint that works fantastic for this application.Mask it up and then paint..No primer needed.Get it from auto bahn etc.etc
#3 _rorym_
Posted 06 May 2006 - 11:28 AM
Think he meant the colour strip in the middle Phil.
#4 _Bomber Watson_
Posted 06 May 2006 - 01:05 PM
to do it properly, mask the area, use about three or four runs of tape over the edges. then sand with 320 grit. mask first so you don't scuff the bits you don't want painted!! then remask if nessecary, and spray it with etch primer. protec stuff is good. then sand again with 400 and spray it with whatever top coat you want. again i recomend protec gear.
probably not terrably efficiant if thats all you want. you will end up buying much paint for no reason, plus you need spray gear. if you were around here i'd do it for you for $30 or so to cover materials.
i think power plus makes an etch primer, so that might be the go. just follow the same directions as above.
Posted 06 May 2006 - 09:19 PM
Thanks a bunch gents
Bomber: Thats the info i was after. I'll do it as you suggested. I have access to some spray gear.
Perhaps I can use the extra paint to fill some chips I have from car doors *grumble*. Its great when people respect your car, isn't it? At least they didn't dint too bad and the primer is still bonded.
Edited by smeer, 06 May 2006 - 09:19 PM.
