Oxy Cutter VS Plasma Welder
#1 _Viper_
Posted 01 December 2010 - 06:52 PM
Now ive never seen a plasma cutter in action and from what I can gather its pretty similar to a oxy cutter so im just wondering what are the advantages/disadvantages compared to oxy?
One I read was that Plasma cutter can cut alloy where Oxy cant, I guess this is one of the biggest ones? But my grinder seems to cut alloy ok (thickest ive worked with is 3mm) I can see thicker stuff being a problem.
On that subject can you get specialized discs for ya grinder and drop saw to cut alloy?
Posted 01 December 2010 - 07:00 PM
#3 _Viper_
Posted 01 December 2010 - 07:10 PM
So could you cut thin sheet ie 1mm and not distort?
#4 _Kush_
Posted 01 December 2010 - 07:15 PM
I've cut 8mm aluminium sheet with a jigsaw (need aluminium cutting blade)
The dropsaw discs are available but I don't know how much they cost. It's probably a bit scary though.
Oxys are also good for heating/bending. Plasmas can't do that.
Posted 01 December 2010 - 07:16 PM
Yes,you can get grinding wheels specifically for ally.
These guys make great product, http://www.pferdusa..../206/index.html ,google is your friend regards suppliers.
Whoever sells the discs can help you out with wax as well.
Posted 01 December 2010 - 07:31 PM
Use wax on your drop saw.
Im not that keen on plasma cutters......and Ive used them often.
Im not saying they are not a good tool,but shit catches alight easy when you are using them on cars,and cleanup can be a pain in the arse if you are not using spotless,new material.The edges need to have any
trace of slag removed as well if you are tig welding..
Plus,you need a pretty good air compressor to keep up with them.
I reckon you can do a neater job with a 1mm cutting wheel in many situations....a jigsaw with plenty of lube is great for curves on ally,and if you mask up the surfaces with duct tape you will avoid most scratching.
Im also not a big fan of dual-function tools.They are generally a compromise and have twice as many things to breakdown,rendering them useless.
My opinion only.
Posted 01 December 2010 - 07:36 PM
Posted 01 December 2010 - 07:43 PM
#9 _Quagmire_
Posted 01 December 2010 - 07:56 PM
my weapon of choice
just make sure you remove the fuel first lol
#10 _nial8r_
Posted 02 December 2010 - 07:32 AM
