Holden 6 Oil pressure
39 replies to this topic
#26 turbotrana
turbotrana
  • 155 posts
Posted 24 December 2010 - 01:55 AM
Blueprint or clearance the pump and you will get enough at idle to not be a problem
#27 _Mike73_
_Mike73_
Posted 05 January 2011 - 11:11 AM
^^^+3.
Be careful using a high volume oil pump if you don't have an increased capacity sump.
Don't know how true this is, I've heard stories about all the oil being pumped up to the top of the engine at high revs and not much left in the sump so the bottom end gets starved.
Can anyone with 1st hand experience confirm.
Done plenty of hard revving in a 186 and never ran out of oil, from memory yella Tella head ( which I had )they drilled out the return diagonal holes. ( in the line of the rocker posts ).
There may also be a myth associated with this aspect also, the reason I say this is because the 202 heads have at least double the return rate as the adjustable type heads.
So I gather if there are sometimes problems it would only be in the pre 1972 era 6cyl engines and XU-1 engines, also a engine with sludge forming would have returns starting to retrict the return flow too.
A normal 202 head 2811930 has clearance on the push rod holes ( all 12 of them ) this in addition to the earlier type return holes which were still drilled diagonally through.
Early 138, 161, 179,186 and XU-1 heads had special flat sidded broached holes that were guides for the push rods, this is why there is always shiny marks on the push rods on these engines.
While these broached holes do have clearance in one plane, the back and front are a close fit and minimal oil would return past the push rods, except for the diagonal holes drilled which lead into the push rod holes further down than the push rod guides.
These heads have three or four return holes plus what ever can escape through the restrictive push rod holes, this will be minimal in a cold engine I suppose.
Mike
#28 _arsnic_apple_
_arsnic_apple_
Posted 05 January 2011 - 11:31 AM
So even with a freshly built 6 cylinder we should be still running a thicker oil
such as hpr30 and above?
Cheers Blake
#29 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 05 January 2011 - 06:46 PM
^^^+3.
Mike
:Headbang2:
send a drill down the pushrod tube and get rid of the flat sided holes and use guideplates.
to Spack,
ive drilled the tubes, deburred the head, i didnt drill the drain holes out that are next to the rocker post, but i smoothed the outside of them and the large drop leading to the hole inbetween the rockers posts i smoothed etc. i smoothed the edge's and made a radius on the drain holes between the lifters and also send a drill through and radius the hole that goes from behind the sideplates to above the timing gear. just the small things that add up but you have probably already done most of this.
with an EH Sump with standard capacity and hpr30 penrite oil & yes it has a hv pump, it still has oil pressure at the other end of the strip, crosses the line at 6200.
#30 _glennhailstone_
_glennhailstone_
Posted 26 March 2016 - 12:29 PM
Remove the pressure relief valve & fit 2 or 3 washers behind the spring. That should lift the pressure a bit. The cam bearing clearance will alter the pressure as well, I've fitted cams in engines & the oil pressure has changed with no other alterations. A change to HPR 40 may help as well, but play with the relief valve 1st.
Hey my engine builder told me to do this. Could you please explain it for a dummy like me to understand. Do the washers go between the spring and the plug (bolt that screws into the end that holds the spring in). Maybe a photo would be good.
I would suggest if you have opened up the holes to let more oil through then use this method to get a bit more pressure.
Edited by glennhailstone, 26 March 2016 - 12:37 PM.
#31 _Muzzy_
_Muzzy_
Posted 26 March 2016 - 04:10 PM
Between the spring and the end plug, bear in mind this will only effect maximum oil pressure, so any low oil pressure issues will not be solved by this method
#32 _glennhailstone_
_glennhailstone_
Posted 26 March 2016 - 04:24 PM
Oh, thanks for that
#33 _oldjohnno_
_oldjohnno_
You really shouldn't be messing with the relief valve unless you absolutely have to. And in itself oil pressure doesn't tell you anything, it's just an indication of resistance to oil flow. It doesn't tell you anything at all about the flow volume, and that's what matters. The Holden six pump is a bit smaller than average for an engine of its size, but that's OK and it's actually a good thing if the rpm range is raised.
And in particular I'd warn against using using thick oils (hello Penrite, you fukwits) to artificially raise the pressure reading. Yes, the needle may sit a bit higher than it did before but by using the thick oil you've almost certainly reduced the flow rate by a small amount. These motors don't need much pressure at all - if it's off the peg at idle and around 45 at speed you've got nothing to worry about.
#34 _glennhailstone_
_glennhailstone_
Posted 26 March 2016 - 05:16 PM
"Well, sir, you are a cowardly son of a bitch! You just shot an unarmed man!"
"Well, he should have armed himself if he's going to decorate his saloon with my friend."
Edited by glennhailstone, 26 March 2016 - 05:22 PM.
#35 orangeLJ
Posted 26 March 2016 - 10:40 PM
My 202 sits at basically nothing when got (mechanical automater procomp gauge)
But has plenty once revs climb.
I used to stress, now... Honestly I don't GAF
Last engine was similar, when I pulled it down, it was perfect inside, no excess wear, bearing nice etc etc.
If it pops from idling with no oil pressure when hot, then it was always going to pop at some stage anyway
#36 _glennhailstone_
_glennhailstone_
Posted 27 March 2016 - 04:25 AM
ok thanks, nice Torana
#37 _glennhailstone_
_glennhailstone_
Posted 27 March 2016 - 12:44 PM
Interesting, after putting a nut in the oil pump. I just noticed oil dripping out of the sump gasket... Might take the nut out
#38 _oldjohnno_
_oldjohnno_
Posted 27 March 2016 - 01:19 PM
DO NOT overshim the spring! This is why I urged caution re shimming the spring - shims not only increase the spring preload, they also can limit the plunger travel. And this can cause pressure high enough to damage things at high rpms. Check that it hasn't blown the gasket between the pump and block, causing it to appear as if the sump is leaking. Then pull the damn nut out of it and leave it alone until you know what you're doing. It's possible to shear the drive pin, strip the gear or pop the filter by doing shit like this, and if that happens it can wipe out your engine. Lowish oil pressure won't hurt a thing; a broken oil pump will hurt lots of things.
Edited by oldjohnno, 27 March 2016 - 01:24 PM.
#39 _glennhailstone_
_glennhailstone_
Posted 27 March 2016 - 01:43 PM
Bloody hell! Hahaha
#40 _glennhailstone_
_glennhailstone_
Posted 27 March 2016 - 06:27 PM
Took the nut out, there were a couple of not loose but not tight sump bolts. I think the added pressure just found the easiest way out. Anyway no more mucking around with the oil pump for me!
