g'day...
im just after a few oppinions on carbs for a holden 6.
In my case im looking at what would go better on a 6, built primaly for the
drags.I've seen a bloke from up north, run like a 650dp on a 202, on methanol
and it hauld ass, ran constant 12.8 in an lj torry with an auto and before that, they had webbers on pump gas with a 4 spd running 13.0 @ 101, so i'd imagine both carb setups would go good in the right circumstance.
Has anyone had any experience with this?
cheers pete
go fast carbs
_runna_202_
, May 07 2006 08:00 PM
4 replies to this topic
#1 _runna_202_
Posted 07 May 2006 - 08:00 PM
Posted 07 May 2006 - 09:10 PM
Any Holley will only perform well if you've got the manifold vacuum to match it. A 650DP is huge for a six, so that engine must have been absolutely wild. I also don't know what manifold he would have been using.
What are the specs on your motor?
Edited by Heath, 07 May 2006 - 09:10 PM.
#3 _[BOTTLEDUP]_
Posted 08 May 2006 - 12:11 AM
650 on meth would have been alright on an outright drag engine, not a street car.
#4 _knighty_
Posted 09 May 2006 - 12:18 PM
although drag racing isn't about driveability, i have seen a 780 on a na. hemi 6 running an 11.4A 650DP is huge for a six
most warm 245/265s run 600 - 650s but this may well be due to the breathing characteristics of these motors,
out of curiosity what's the cfm work out to for a set of tripple 1.75s or tripple 2"
#5 _runna_202_
Posted 09 May 2006 - 08:01 PM
this motor in the early stages, as i dont have 2 many specs yet...
the head is a 12port ported by warflow in gladstone qld, the figures are around
300hp @500''. hes going to match a cam for it at a later date.
I've got yt 5008 rockers, and a set of 175 su's.....thats about all the specs,
just wondering what carbs ppl use on race 202's..
thanks for ur help guys...pete
