gear box ?
54 replies to this topic
#1 _lxclone_
_lxclone_
Posted 16 December 2010 - 03:37 PM
hi all
looking for comments and ideas for the type gearbox for the hatchback
had this quote!!
looking at 400hp.. bit of street... manily club days etc
Hi Tom,
I have listed below the parts and pricing for a TKO 600 for your LX Torana.
TKO 600 Close Ratio 5 Speed - $3050
Alloy Bellhousing - $550
Hi-Torque Starter Motor - $435
ACE 11� Billet Steel flywheel - $495
ACE 11� Premium High Performance Clutch kit - $880
ARP Flywheel Bolts - $55
Spigot Bush - $20
Hydraulic Bearing $390
Underdash Hydraulic Pedal Unit - $790
Braided Hydraulic Line - $160
Speedo Cable - $78
Speedo Gear - $39
Hurst Gearstick - $120
Hurst Gearknob - $65
31 Spline Slip Yoke - $175
Gearbox Mount - $45
Crossmember - $225
#2 _rocket_
_rocket_
Posted 16 December 2010 - 07:36 PM
Lot of $$$, lots of other options .
#3 dattoman
Posted 16 December 2010 - 08:06 PM
Do it
You will love it
#4 76lxhatch
  • 7,215 posts
Posted 16 December 2010 - 08:13 PM
When the gear knob alone costs $65, that's a serious bit of kit.
#5 _nemo355v8_
_nemo355v8_
Posted 16 December 2010 - 08:33 PM
Over kill for 400 HP. But sure as hell be nice to have.
#6 _lxclone_
_lxclone_
Posted 17 December 2010 - 05:06 PM
thats the first thing i picked on seems a bit extravagant!!!
the gear box it'self seemed ok till i had some lead on super t10 new for 1700 from u.s
#7 _lxclone_
_lxclone_
Posted 17 December 2010 - 05:14 PM
what's your recommondation?
#8 _nemo355v8_
_nemo355v8_
Posted 17 December 2010 - 06:41 PM
G force T5 hadles the same power as TKO 600 A grand cheaper.
or a G force kit to put in a second hand T5 kit is $1300
Yella terra fly wheel $300
hard core clutch from Sunbury clutch and brake off Ebay think I payed $350 for mine.
Bellhousing kit from CRS or Dellow around the $550 with X member.
By my time sheet at the drags I have 420 HP and use a standard T5, if treated ok a standard T5 would be up to the job. Any where from $100 to $450
Under dash pedal unit ? X member $225 what the.
If the money is there to spend the TKO and bellhousing would be ok but the price for some of the other stuff is a bit steep.
#9 rodomo
  • 18,051 posts
Posted 17 December 2010 - 09:30 PM
You could blow up 4 aussies for that price. :tomaatit:
#10 myss427
myss427
  • 1,636 posts
Posted 17 December 2010 - 09:49 PM
You can do a lot cheaper if you source most of the stuff your self, Centreforce clutch from the states is $300, hydrolic thrust is $145. High torque starters are $200 tops. Speedo cable is standard powerglide, turbo 350 with ford T5 mustang speedo gear and adaptor. A lot of the bits there are as said over priced.
#11 _lxclone_
_lxclone_
Posted 20 December 2010 - 08:06 AM
i thanks you all for the input
i will be checking out the options over the break
t
#12 _rorym_
Posted 20 December 2010 - 06:05 PM
That will handle 650HP....as said..over priced...cheaper options available..
#13 antelopeslr5000
antelopeslr5000
  • 1,022 posts
  • Car:1977 LX SL/R 5000
Posted 20 December 2010 - 06:39 PM
Is that quote from Mal Wood?
#14 _lxclone_
_lxclone_
Posted 21 December 2010 - 07:32 AM
yes..... has not been recived all that well!!
#15 _Liam_
_Liam_
Posted 21 December 2010 - 08:29 PM
When you can get a Tremec T56 for 3K, I think the box is the wrong choice.
As said a T5 is way cheaper, even get an old one, get it reco'd and beefed up should still only end up costing just under 2K, easily handle 400 HP.
Outsource absolutely everything... All the time, and ask around every single person in the phone book.
#16 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
  • Car:LXSS, VUSS, VESSv & the mighty HB
Posted 21 December 2010 - 08:55 PM
I suppose it depends on how he wants to go about it, a TKO & CRS bell housing is a hassle free fit but cost more, I�m sure you have to do tunnel modifications to fit a T56 & T5 but cost less.
Just a thought.
#17 _Liam_
_Liam_
Posted 21 December 2010 - 10:15 PM
Just a thought.
Yeah I'm pretty sure you do, but thats pretty straight forward as well, still pretty cheap, just cut a channel out and then put some new metal in, rounded to meet the existing tunnel, with some bracing channel at the back of which, would probably take someone 5-6 hrs and approx $50. Still the better option in my opinion.
But you are right, however he wants to go about it.
#18 _nemo355v8_
_nemo355v8_
Posted 22 December 2010 - 05:10 PM
I suppose it depends on how he wants to go about it, a TKO & CRS bell housing is a hassle free fit but cost more, I'm sure you have to do tunnel modifications to fit a T56 & T5 but cost less.
Just a thought.
Ford 6cyl T5 only needs the shift hole making a little longer to clear the shift housing, or lower the box slightly. No other tunnel mods required.
#19 its Paul
its Paul
    Formerly lx8vd77
  • 1,577 posts
  • Name:Paul
Posted 22 December 2010 - 09:38 PM
If you want to use the console, you can�t go modifying things too much other wise it won�t fit.
It depends on the budget you are running on, if it�s in your budget and what you want, then go for it.
When in, it should look something like this :buttrock:
#20 _lxclone_
_lxclone_
Posted 23 December 2010 - 09:07 AM
theres some interesting info here...
buget has to be under control as like most of us we want the best but ...how much $$$$$
the t5.... this was in Commodore and fords ...behind 6cy? most of what you are talking about i am having to research sorry if i can have a input what modle or year should i look for with the t5??
i had to start some where with this... i have no problem altering the floors as i have to replace them any way.
i come back into this car building after a 30 year break developing a family...:))
at 52 theres much to learn the project was to have started 2 years ago but thing when a bit off track ..but all good now.
i have 2 hatchbacks a lx and a uc my original plan was the uc lx convertion as i wanted to custmise every thing about it but then the lx came up
except for the floors the car is rust free...after thinking about it for a year or so i wounder weather i should continue with the uc convertion rather than the lx as the lx would make a great restoration project for a enthusiast who want the original deal.... where i would possably be changing somethings aout the lx.. i know can hear now ...i will have the hatch if you dont want it ...not made up my mind yet..
many thanks for the input
tom
had another quote for richmond super t10
Hi Tom,
T 10 new is $3399 and shifter is $399, you will also need to change your
Bell housing $550. Freight is Adelaide $50
Kind Regards,
Grant Munday
GMP Racing Products Pty Ltd.
20b Clifford Street
Huntingdale, VIC 3166
AUSTRALIA
#21 76lxhatch
  • 7,215 posts
Posted 23 December 2010 - 10:11 AM
Came behind sixes and V8s, different ratios etc but same box. Start with the bell housing - that will dictate which box you need as the input shaft lengths are different, and there are a couple of different bolt up patterns.
It would be worth having a good look around at what's available second hand too, you may find some good stuff available with most of the parts you need for a fraction of the brand new price.
#22 myss427
myss427
  • 1,636 posts
Posted 23 December 2010 - 12:00 PM
I bought a brand new W ratio T10 from Jegs USA, last year for $1650 freight was $400 to Australia. In 3 days it arrived, so someone is making a buck at $3399!
#23 _lxclone_
_lxclone_
Posted 23 December 2010 - 12:49 PM
why w ratio?
#24 _lxclone_
_lxclone_
Posted 23 December 2010 - 01:11 PM
is this in the right direction
http://cgi.ebay.com....=item2c59971c98
#25 myss427
myss427
  • 1,636 posts
Posted 23 December 2010 - 02:36 PM
I liked the ratio spread for a street car, it has a good first (2.64 )not two long and great space between 2nd and 3rd (1.75 -1.51). Very close to depress ratios.
