BMW wheels
#26
_CHOPPER_
Posted 07 November 2011 - 01:40 PM
The load is designed to be carried by the centre hub, the nuts are just for securing the wheel.
#27
Posted 07 November 2011 - 02:18 PM
Just out of curiosity, what size is that centre lug on a HQ?
s
#28
_CHOPPER_
Posted 07 November 2011 - 09:59 PM
#29
Posted 07 November 2011 - 10:54 PM
As close a fit as the center locator ever was it would always have to be a smaller diameter than the wheels center bore to allow ease of fitment and theoretically could not take load.
What the center bore locator's roll is exactly as the name suggests, they center the wheel on the hub so that the studs are not in contact with the bores of the wheel. Why is this important. As I understand it what hold the wheel onto the hub or better put what takes majority of the force is the friction between the wheel mounting face and the hub. The nuts properly afixed to the studs applied force mating these two faces together.
If a wheel is not centered and then affixed you will create point loading and a variance in the force distribution across the studs. This can also result in the scenario where a stud is taking the load instead of the friction between the two mounting surfaces, Effectively the bolt will come under a double shear load, which in this circumstance, the stud is not designed to take and introduces the chance of failure.
my 2c
#30
Posted 08 November 2011 - 06:47 AM
BMW is (from memory) 74.5mm
I think BMW have a few different sizes depending on the model. My hub rings are 69.6 / 72.6 and they're a snug fit.
s
#31
Posted 08 November 2011 - 06:53 AM
These days with conical nuts and mag nuts that fit into the wheel holes they'd align the wheels up correctly right?
With the HQ's having a slightly different PCD do you have to file away the bores? Also with a larger centre locator would you have to widen a Commo wheel centre hole to suit?
s
Edited by StephenSLR, 08 November 2011 - 06:54 AM.
#32
Posted 08 November 2011 - 08:33 AM
But!!! It is a common misconception that Hubcentric wheels carry the weight of the car, it is always the friction force between the two mounting surfaces as a result the of force of correctly torqued bolts.
http://forum.miata.net/vb/archive/index.php/t-127227.html
Read this thread it covers most of the obvious.
Im 3rd / 4th year mech. Engineer working in a design and cert. roll and after making that statement last night even I sort further information to reassure I was happy with my statement.
What I will tell you in regards to having a center bore locator on your rims is that it is cheap insurance. I say that because there is a greater chance that you will center the wheel on the hub with this set up and avoid any off center loading that may be introduced by the various centering style nuts.
Its too later to address this issue after you have lost a wheel.
PS it is very, very, very bad practice to bore out a hole to make it fit. The friction force between mounting faces as a result of the torque on the stud is calculated at an ideal state. That being centered wheels with fasteners having symmetric loading under the fasteners ect. Even with the included safty factors the slight introduction of this sort of a change will throw out all of the engineered calculations and could result in a chain of events that could result in losing a wheel.
I am not versed in the correct procedure regarding having a larger hub diameter than the wheel center bore. I can see a couple of options. Have the center bore widended (depending on what the wheel will allow), custom hub? (I take it you have the hoppers hub, could this be machined down?), different wheels.
#33
Posted 08 November 2011 - 08:45 AM
I agree.
I take it you have the hoppers hub, could this be machined down?, different wheels.
You may have misunderstood, I was asking out of curiosity.
I do have the correct Commodore sized locators, they are interference fit and if they were HQ the Commo stockies wouldn't have fit. I also have Commo stud pattern/PCD both front and rear.
s
B.Eng. (Mechanical)
Edited by StephenSLR, 08 November 2011 - 08:52 AM.
#34
Posted 08 November 2011 - 09:43 AM
#35
Posted 08 November 2011 - 09:57 AM
haha! there are a few of us on here then lol
True and sure I may have a degree but I never discount the word of people in the field as they are often far more knowledgeable. They get to experience results first hand and see all the variables that come into play that can make short work of what seems to be 'good designs'.
s
Edited by StephenSLR, 08 November 2011 - 10:10 AM.
#36
Posted 08 November 2011 - 10:07 AM
True and sure I may have a degree but I never discount the word of people in the field as they are often far more knowledgeable. They get to experience results first hand and see all the variables that come into play that can make short work of what seems to 'good designs'.
s
very ture and a statement I fully agree to.
#37
Posted 08 November 2011 - 10:42 AM
i recon these would look good on it!
What do they look like without the centre caps? Curious to see if they'll look a bit more like hotwires.
What offset? I notice they come with different offsets dependent on what size and model they're off.
s
#38
Posted 08 November 2011 - 11:36 AM
Sheesh, for a mechanical engineer you have terrible spelling and grammar
Actually, that would make you an excellent engineer! The best engineers I have come across dont speak much English! haha.
Chris
b. bus (marketing)
b. smartassery
(all in jest)
#39
Posted 08 November 2011 - 11:52 AM
I've noticed this a lot, particularly lecturers.
s
Edited by StephenSLR, 08 November 2011 - 11:52 AM.
#40
Posted 08 November 2011 - 01:47 PM
I will attempt to address that OJ, most of my attention is actually on calculating the natural frequency of a reduction gear system atm loll.
don’t stress, the numbers are correct....
#41
Posted 08 November 2011 - 02:01 PM
s
I think they look like shit without the caps lol. Ill grab a pic and throw it your way the next time I have a chance.
dont know the offset but they are the same as these....
http://felgenkatalog.auto-treff.com/
Edited by TempesT, 08 November 2011 - 02:02 PM.
#42
Posted 08 November 2011 - 02:08 PM
Ohhh man i fail at spelling and grammar especially on the fly. I’m just lazy don’t take the time out to look at what I’m typing.
Only having a dig man!
I honestly couldn’t give two hoots how people spell or punctuate their sentences, I'm just as terrible (if not worse) most of the time!
I just saw an opening for me to have a crack at another profession and went for it! haha.
A company I used to work for manufactured container forks and other heavy machinery, the head engineer was a polish bloke, second in charge was a Serbian, both spoke terrible English, typed was excellent surprisingly, written was ok.
The plebs of the office were a couple Asian guys and the middle level stuff was all aussie!
Takes all kinds I suppose!
#43
_CHOPPER_
Posted 08 November 2011 - 02:20 PM
Chopper I cant find any reason why the center locator would hold any load what so ever and i believe that statement to be incorrect.
I never said that. I made two seperate statements. The hub rings, centre bore locaters (call them what you will) are designed to minimise vibration due to rims that are not centrally located on the hub.
#44
_CHOPPER_
Posted 08 November 2011 - 02:27 PM
s
Back in the 90's when pimply faced 18 y/o kids put BMW mags on their rusty VB Commodores, we generally used 74.5/69.6mm adapters. But that was nearly 20 years ago, so my memory may not be correct or they do have different centre bores.
#45
Posted 08 November 2011 - 02:52 PM
#46
Posted 08 November 2011 - 04:51 PM
There's a few different 'styling 5' on that page, they all look somewhat different particularly the outer rim and have many different offsets. There should be a stamp on the inner hub the letters ET followed by offset number if memory serves me correct.
s
#47
Posted 08 November 2011 - 06:53 PM
I work 250km from home so ill have a look on friday for you.
#48
_CHOPPER_
Posted 08 November 2011 - 08:07 PM
Ok Chop. I didn’t mean to come across rude. It was mentioned on the first page by another member and your statement could (and was by me) have been misconstrued. I think we are all on the same page now lol.
You didn't come across rude at all. You simply asked what you thought was a valid question. No problem at all.
#49
Posted 08 November 2011 - 08:31 PM
they are the Kreuzspeichen-Styling
Taking another look they actually look like the Kreuzspeichen-Styling TRX as the spokes sit in a rim within the rim, the spokes on the Kreuzspeichen-Styling go all the way to the outer rim.
s
#50
Posted 08 November 2011 - 08:45 PM
Especially the wannabe ones making stupid little cars for projects
Trying to understand hydraulics and making things they think will work... then realising in the real world they don't .... grrrr
