Hi all, I was just wondering if there are any off the shelf turbo cams available to suit a holden 6. I need something to use for my turbo 202 build.
If so who manufactures them and what is the part number etc.
forced induction cam for Holden 6?
Com_VC
, May 08 2006 08:09 PM
10 replies to this topic
Posted 08 May 2006 - 08:09 PM
#2 _CHOPPER_
Posted 08 May 2006 - 09:00 PM
I'm fairly sure Crow does. Any cam grinder should be able to grind up whatever you want.
Posted 08 May 2006 - 09:01 PM
Most manufacturers should have one..a cam selection sheet would be a good bet.
My recommendation would be to get it up and running with a stock cam and see how it goes.
#4 _coupe202_
Posted 08 May 2006 - 09:11 PM
use a wade 259a cam works well on turboed engine.
#5 _CHOPPER_
Posted 08 May 2006 - 09:13 PM
Wouldn't that depend on how much boost and how many revs you want to use?
#6 _coupe202_
Posted 08 May 2006 - 09:28 PM
boost depends how much you put into it and the engine will only rev to 5000rpm that for stock engine with no head work. i used this cam in a 179 with 15psi and it ran 13.7. its a good little cam.
Posted 09 May 2006 - 05:12 PM
Reckon 35616 would be a good choice?
http://www.crowcams....e-Holden6.shtml
I heard that it's best not to have any overlap? So 35616 should be ideal?
I've got a new wade 259a sitting here so that might be an option as well
#8 _coupe202_
Posted 09 May 2006 - 05:46 PM
more head work the engine will turn to 6000rpm and another thing is what carby are you going to use.
Posted 09 May 2006 - 06:06 PM
going to be EFI. would like to make a bit of power
#10 _UCV80_
Posted 09 May 2006 - 07:28 PM
there is a 35616 on ebay for $50 if u dont wana spend much !
Posted 10 May 2006 - 04:28 PM
not too sure on that one, might be a little too wild? any comments?
