Speedo Gear F.A.Q.
58 replies to this topic
#26 arrimar
arrimar
  • 3,134 posts
Posted 17 March 2007 - 02:46 PM
hmm ..where do we insert downforce from bootlid spoiler at speed into the equation?
do i measure from the leading edge of the grease spot or a guesstimated centre?
#27 _devilsadvocate_
_devilsadvocate_
Posted 17 March 2007 - 05:30 PM
Yes it gets harder when the car is moving!(but at least get it right as it can be 1st) downforce from the spoiler? are we talking ricers here? to a degree conteracted by the carcus of the tyre moving radially outwards as the tyre is spun faster.
#28 arrimar
arrimar
  • 3,134 posts
Posted 17 March 2007 - 07:08 PM
this is fun DA.
the old DA would never have allowed counteracted or carcass to slip through.
bootlid spoilers belonged to we of the muscle prior the propagation of rice.
anyway chop chop will want his thread back soon.
permission to remove any or all of my input is granted.
#29 _CHOPPER_
_CHOPPER_
Posted 17 March 2007 - 07:41 PM
* waves magic wand to remove BS *
Hmm... all the BS is still there.
* pulls pants back up *
Crap on all you want. If somebody wants my help and posts ALL the info I ask, they will get an answer.
#30 _tyre fryer_
_tyre fryer_
Posted 18 April 2007 - 02:55 PM
Hi chop. this is getting confusing to me.
my uc has an aussie 4-speed and 205/60/13 wheels. it had a 3.36 diff until that blew up. I changed it to a 3.08 and now its reading incorrectly (42km/h is about 50km/h).
can you please tell me what speedo gear i need to change it o.
dad is out there now checking the gearbox gear.
#31 _CHOPPER_
_CHOPPER_
Posted 18 April 2007 - 07:53 PM
24 tooth
#32 _tyre fryer_
_tyre fryer_
Posted 18 April 2007 - 09:24 PM
you sure?
cos I used all that stuff that was posted before to calculate it and i worked out it needed LESS teeth. meaning it needed 22t dark blue. BTW the driver gear was white and the speedo gear was red.
#33 _CHOPPER_
_CHOPPER_
Posted 19 April 2007 - 09:18 AM
Sorry, I used the 3.36 diff in the calculation. 22 tooth is correct with 3.08 gears.
#34 _jklumpp_
_jklumpp_
Posted 19 April 2007 - 01:33 PM
So does anybody know about Supra Boxes?
I measured with the GPS the other day, and with the speedo reading 100kph, the car was doing 116kph....
Does anyone know if there are different gears for these boxes?
#35 _jap-xu1_
_jap-xu1_
Posted 22 April 2007 - 11:15 PM
Despite the fact I have posted it several times, most people can't seem to work it out. For the game few:
Driven Gear = 512.27 x diff ratio x drive gear / tyre diameter ( in millimetres )
can i just get some clarification on the formula please chop chop.
first up here is a link to the rare spares page showing all the gears
https://rsp-secure.c...a...C LJ TORANA
ok now the driven gear is the one that you can push in the side of the gearbox right so we need to identify the colour of the drive gear which is installed on the output shaft of the gearbox,can be seen through the speedo drive hole i assume?
so the formula is
512.27 ,multiplied by
diff ratio ,multiplied by
the number of teeth on the drive gear,divided by
tyre diameter(rolling distance)
equals the number of teeth you need on the driven gear?
#36 _CHOPPER_
_CHOPPER_
Posted 23 April 2007 - 10:09 AM
You got it right apart from the tyre diameter. Diameter is the distance across the centre. Rolling distance is meaured by placing a tape measure around the outside of the tyre. As posted in the other thread I started:
205/65R15 diameter =
(205 x 0.65 x 2) + (15 x 25.4)
If you worked it out correctly, you should get 647.5 mm
#37 _jap-xu1_
_jap-xu1_
Posted 23 April 2007 - 06:12 PM
sweet man,
wicked info!
#38 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 26 June 2007 - 12:20 PM
Hi there,
Could someone help me. I have a LH torana running a steel case celica 5 speed gearbox. Wheels are standard 185/70 13inches. Diff is 2.78. What gear do I need? My speedo at 60kms shows aprox 40 km/hr.
Cheers,
Phillip
#39 _jklumpp_
_jklumpp_
Posted 26 June 2007 - 01:42 PM
to help with the above, after some research yesterday i found that the W55/57/58 Supra gearboxes have either a 10 or 11 tooth drive gear, and driven gears are available in 30, 31, 32, 33, 34, & 35 tooth.....not sure if the Celica's were the same?
Edited by jklumpp, 26 June 2007 - 01:43 PM.
#40 _toddy_
_toddy_
Posted 28 June 2007 - 09:40 PM
hi chopper could you please tell me what gear I need in my m21?
I have 2.75 gears with 225 50 15s
Thanks in advance
#41 _rookie_
_rookie_
Posted 20 July 2008 - 04:47 PM
hi, hope somone can help, I have a th350 with 2.75-1 diff and 265/50/14's and have no idea what speedo gear I need?
Nick
#42 rodomo
  • 18,068 posts
Posted 02 August 2008 - 01:40 AM
Example:
(Rolling circumference is NOT used in this calculation.
Tyre DIAMETER is what is used.)
Tyres: 225/50/16, DIAMETER of 631.4mm as calculated here:
http://www.miata.net...e/tirecalc.html
Speedo DRIVE gear: (found in gearbox extension housing) 8 teeth.
Diff RATIO: 3.08:1
So......
512.27 X 8 (DRIVE gear teeth) X 3.08 (RATIO) = 12,622.332
12,622.332 divided by 631.4 (mm DIAMETER) = 19.991023 or 20 teeth on your DRIVEN or speedo cable gear.
#43 _CHOPPER_
_CHOPPER_
Posted 02 August 2008 - 04:02 PM
Rob, since the formula has been given out several times ( including in this thread ) it appears fairly obvious to me that the above three members couldn't work it out for themselves. What makes it a bit trickier is that the T350, 400 @ 700R4 have different numbers of teeth on their cogs, as well as different colours.
#44 rodomo
  • 18,068 posts
Posted 02 August 2008 - 04:09 PM
Chop,
There has been another thread where a member was having trouble understanding the formula.
My above post has been copied and pasted into this thread as this thread is a sticky.
#45 _stu.slr_
_stu.slr_
Posted 02 February 2009 - 08:11 PM
A question with all the info I need to give an answer. 24 tooth gear.
* hint to all others *
gday chopper, my car has a tri, 2.78 & 235/60/14 tyres. ant help on what speedo drive would be appreciated thanks stu.
#46 rodomo
  • 18,068 posts
Posted 02 February 2009 - 08:39 PM
I think Chopper is off line at the moment after his house move? :huh:
You need a blue drive gear in your g/box extension housing.
Rare's part no. SG1001 (9 teeth)
And
You need a white driven gear on the end of your cable.
Rare's part no. SG1007 (20 teeth)
#47 _arsnic_apple_
_arsnic_apple_
Posted 02 June 2009 - 01:39 PM
I have a trimatic, 2.78 diff, the white drive gear (8 tooth) and my tyre diameter is 651mm (225/60/15).
The formula works out to 17.5?? :huh:
Do i have to change the drive gear or sumthing aswell? How hard is it to change the drive gear?
Thanks Blake
#48 Orange SS
Orange SS
  • 523 posts
  • Car:1976 LX SS Hatch
Posted 18 June 2009 - 03:12 PM
Hi,
Ive just changed to a 3.55 diff(was 2.78) and have 215/60/14 on rear and 195/60/14 on front.
Can anyone tell me which speedo gear to put in the trimatic I have.
#49 rodomo
  • 18,068 posts
Posted 18 June 2009 - 11:30 PM
Thanks Blake
Your's is a bit difficult.
If you use a 17 tooth, it will make your speedo read faster than the car is going and might save you a fine here and there.
It would be closer with a blue drive gear in the trans and a 20 tooth driven gear in the cable but the speedo would be reading slower than the car is going.
I'd go the 17 with the 8 if it were me.
You would have to remove the extension housing to change the drive gear. You can do it in the car but a pain in the butt.
#50 rodomo
  • 18,068 posts
Posted 18 June 2009 - 11:38 PM
Hi,
You would need a 24 tooth yellow gear in the end of the cable if you have a white gear in your trans.
