mini tubbed lc/lf
15 replies to this topic
#1 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 09 May 2006 - 08:47 AM
i'm want some pics of a torana with mini tubb. Thinking of cutting a set in. I have some pics were they have been cut and spread and plated the gaps, bit rough for me
#2 _chevy_253_torana_
_chevy_253_torana_
Posted 09 May 2006 - 04:21 PM
wat sort of torana mate i got a set of minis in my lc coupe if ya want i could take some photos
#3 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 09 May 2006 - 08:16 PM
lc 2dr
#4 _chevy_253_torana_
_chevy_253_torana_
Posted 09 May 2006 - 10:42 PM
il get some pics tomorrow after school mate depending on if its still raining in my area
as the cars under a tarp
#5 gtrboyy
gtrboyy
  • 3,141 posts
Posted 10 May 2006 - 01:26 AM
I've only got these at the moment.What other pics do you want?
in car
in boot
18's & 1/4 panel
Crappy pics off camera phone,I can get you pics of inside w/arch when I get the time in a few days.
Edited by gtrboyy, 10 May 2006 - 01:36 AM.
#6 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 14 May 2006 - 11:16 PM
got any pics from under the car. i'm going to fit some to granny car. Since i can get tubbs made for nothing might as well do it. And my mate is in the mood to change the car in some way or form.
#7 gtrboyy
gtrboyy
  • 3,141 posts
Posted 15 May 2006 - 07:44 PM
I'll try tommorow if it's not raining or thursday if not raining & I'm not working as pics are hard to see anything in the garage.Check japxu1's msn site it might have pics.
#8 _dannylxss_
_dannylxss_
Posted 19 May 2006 - 11:19 PM
lakeside have you got any picks yet i live in the hume side of town you can come and have a look if you want tell me and ill pm my ph no
#9 gtrboyy
gtrboyy
  • 3,141 posts
Posted 21 May 2006 - 03:03 PM
It's been raining over here so I havent been able to get pics just yet.
#10 _adamlcgtr383blownchev_
Posted 24 May 2006 - 12:33 AM
I would love to mini tub mine, but worried about the shocker setup, what did you do?
#11 gtrboyy
gtrboyy
  • 3,141 posts
Posted 24 May 2006 - 01:13 AM
Mine has a bar welded in between the rails with brackets attached for the tops of the coil-overs.If I could do it again I would have had the lower brackets on the diff swapped over so the shock sits on the inside of the rail & make brackets for the top of the std shocks,that way you could have the shockers at the widest point for better handling & cheaper expense than getting coil-overs,but with coil-overs you can play around with them,change settings for the shocks or raise/lower the car.
#12 gtrboyy
gtrboyy
  • 3,141 posts
Posted 24 May 2006 - 04:03 AM
Dynosteve's ljPosted Image
#13 _jabba_
_jabba_
Posted 24 May 2006 - 08:12 AM
try and keep that clean! :blink:
#14 _dannylxss_
_dannylxss_
Posted 24 May 2006 - 07:56 PM
i di mine a little diffrent to gtrboyy what i did was slice the inner tub and butt it up to the rail put a strip to fill the gap and cot it a bit in the boot to square it off a bit so if you look from the boot it looks semi standard and factory set up is retained :spoton:
#15 gtrboyy
gtrboyy
  • 3,141 posts
Posted 01 June 2006 - 10:20 PM
Lakeside:Let me know if you are still interested & I'll put up the pics of the mini-tubs from underneath & my coilovers.I can put them up in a day or so when I can a bit more time.
#16 gtrboyy
gtrboyy
  • 3,141 posts
Posted 02 June 2006 - 03:14 AM
:furious: Crappy pics but I've only got a camera phone.Bit hard to make out so you will probably have to ask me questions to explain it better.Will get a digital camera one day.pics here Pics looked fine on phone but look pixelated & blurry on photobucket :furious: .
