What time will I run
#1 _timbo_hatch_
Posted 11 February 2011 - 03:32 PM
Hopefully heading out to calder next Friday to see what the Torana runs.
Interested to hear your thoughts on what I might run.
Basic specs of the car are as follows
-LX SS Torana
-406ci SBC, engine dynoed at 530hp pump gas, Pulled 308rwkw on chassis dyno.
-4 Speed Toploader Gearbox, Xtreme Ceramic Button Clutch
-31 Spline 9 Inch diff with 3.55 LSD Centre
-Unsure on exact weight, maybe 1300-1400kg at a guess.
-275/50/15 Mickey Thompson ET Street Radials, with plenty of tread
I don't think I will be launching it off the line with the toploader, but once i hit second will be flat out.
Looking forward to hearing your responses.
Tim
Posted 11 February 2011 - 04:07 PM
Mid 12's... maybe sneak in a high 11 when the confidence improves
Low 11's after a few meetings depending on track prep and those tyres (and a change of diff ratio)
Posted 11 February 2011 - 08:07 PM
#4 _timbo_hatch_
Posted 11 February 2011 - 08:26 PM
#5 _fatlh5000_
Posted 11 February 2011 - 09:38 PM
I will take a punt at 11.9s, and will have every faith in your driving ability !!!
Good luck mate.
Look forward to seeing your timeslips !
#6 _Bomber Watson_
Posted 11 February 2011 - 10:15 PM
Posted 12 February 2011 - 03:58 AM
What do I win if Im closest?
#8 _Quagmire_
Posted 12 February 2011 - 04:16 AM
but 12.5 and getting better
so what's the priuze?
sexual favours not recomended lol
Posted 12 February 2011 - 08:05 AM
You'll run a few tenths slower at Heathcote.
Hopefully you can get a few consistant runs (not too much waiting time). As that will help you improve your PBs faster as you will remember what you did the time before and to change your methods.
308rwkw has the potential to do low 11's for sure! But the toploader won't help your times, and you'll have to really nail your launches!
Practise is the key with this one, don't be disappointed if you run some crap times at first, the more you do it, the faster and faster you will go!
If you were running an auto, with a good stall. I'd say low 11's for sure and 10's aren't out of the question... But yeh, all comes down to your 60ft times.
Posted 12 February 2011 - 09:53 AM
Hey all
#11 _timbo_hatch_
Posted 12 February 2011 - 05:02 PM
Not too sure about a prize, but rest assured Quagmire there will be no sexual favours!
Might just add I have gone 12.99 previously in this car with the old motor.
It was a 350 Chev that made 235 rwhp.
Am really hoping for a low 11 but understand the toploader will be the thing holding me back.
Tim
Posted 12 February 2011 - 06:16 PM
#13 _timbo_hatch_
Posted 12 February 2011 - 09:33 PM
Posted 13 February 2011 - 03:18 PM
#15 _Viper_
Posted 13 February 2011 - 06:31 PM
#16 _TorYoda_
Posted 13 February 2011 - 06:55 PM
I reckon Viper is pretty close to the mark. Have fun!
#17 _timbo_hatch_
Posted 13 February 2011 - 08:43 PM
Just found an old timeslip from when I was running the old engine, ran a 13.029 at 166.92 km/h with a 60' time of 1.832. So hopefully the 60' times will be a little quicker with the new engine
Posted 14 February 2011 - 03:47 PM
If that's the case and you know the car well & know how to drive it, sounds like it will be a fast combo!Fresh gearbox with renagate sequential shifter, so I'll be fkn slammin the gear changes
Mid 11's?
Edited by Heath, 14 February 2011 - 03:47 PM.
Posted 16 February 2011 - 08:10 PM
#20 _timbo_hatch_
Posted 12 April 2011 - 08:07 PM
Ended up racing the torry last month at Calder.
They were having dramas with the track and lights all night,
so I only managed to fit in 3 runs for the night.
Quickest was 12.03 @ 118.5mph, with 1.8 60ft times.
Car certainly has a lot more in it. Didn't get the launches down pat, or the gear changes.
Already have had a glide built, with 5000 stall, currently installing it, and have changed the gears in the 9 inch from 3.5's to 3.9's!
So should be quite a bit quicker next time out.
You guys think it will have a 10 sec pass in it?
#21
Posted 12 April 2011 - 08:34 PM
118.5mph is good MPH for about 11.5-7??
But with a glide, stall and diff gears that really transforms it! I reckon it has a 10 in it for sure!!!! Plus more and more practice will help too!
#22 _HRV74_
Posted 12 April 2011 - 08:49 PM
With the same horsepower, TH700R4 and 4.3's, I ran 11.67 @ 115mph (but having to click 4th gear through the traps due to excess converter slip).
As you've probably found, you won't have a problem with MT ET Streets. I know of a local LX Hatch that has run 8.3's on those, with the help of blown BB chev mind you!
