My 186S: What should i do
#1 _Phoenix_
Posted 10 May 2006 - 08:45 PM
#2 _CHOPPER_
Posted 10 May 2006 - 09:08 PM
Posted 10 May 2006 - 09:13 PM
I'd get some port work and oversized valves, electronic ignition etc, maybe some roller rockers to make her rev a little bit more easily?
Anything you want... Starfire Rods could help you out, a nice cam?
#4 _Phoenix_
Posted 10 May 2006 - 09:53 PM
#5 _CHOPPER_
Posted 10 May 2006 - 10:00 PM
Posted 10 May 2006 - 10:04 PM
Harry Firth put a 161 head on a 186 for a good result but I am not too sure if the 173 will do the same job.
A 186-S in standard trim ie twin choke carby, headers, bigger valves, heavier valve springs and a slight cam gave out 145HP.
Have you thought of putting on a quadrajet carby instead of triples? Mabybe easier to tune.
Good luck on your project
Regards ................... Barry
#7 _Phoenix_
Posted 10 May 2006 - 10:10 PM
Posted 10 May 2006 - 10:14 PM
Posted 11 May 2006 - 02:35 AM
How much does it cost to get bigger valves? What does it involve?
Is it machining the valve holes bigger and putting bigger valves?
My 6 has already got hardened seats, but standard valves. Will these new seats just be machined away?
Posted 11 May 2006 - 09:57 AM
What Heath said about the heads is correct.
149, 161 & 173 heads all have the same small (45.4 cc) combustion chamber (Not counting the special order, Lo-Comp versions).
179, 186 & 202 have the same large (53.5 cc) combustion chamber.
If you put a small chambered head on a 186 block you will end up with around 10:1 compression, which , as mentioned earlier is exactly what Harry Firth did in building the XU-1 motor.
By the way Phoenix, what's a 'solid crank' ?
Dr Terry
#11 _Keithy's_UC_
Posted 11 May 2006 - 11:24 AM
Keith
Posted 11 May 2006 - 12:49 PM
To my knowledge, the standard port size for all red motors (except XU-1) is the same.
Dr Terry.
Posted 11 May 2006 - 04:51 PM
Smeer, I'm no engine builder but I expect you'd be getting your hardened valve seats machined out anyway (and it may actually cause some problems having the sleeve sitting in there; join problems for machining) so.
I'd say either talk to an engine builder or do the work on a standard head, get the valves way oversized and then stick sleeves in there to make them the size you want.
#14 _CHOPPER_
Posted 11 May 2006 - 06:41 PM
Posted 11 May 2006 - 08:10 PM
To make sure that is a 186-S motor, the prefix of the engine number should have 186S or 186K.
My ex HR 186S Premmy had the 186K prefix.
Regards............. Barry
#16 _Phoenix_
Posted 12 May 2006 - 09:39 PM
