V6 Ecotec Miss
_Woodsy_
Posted 16 February 2011 - 03:58 PM
I thought it may be the fuel flow regulator as when i pull the vac hose off it the hose is slightly wet. The car will still run with the regulator vacuum disconnected.
I've pulled the Throttle position sensor out and made sure that is working, i've checked fuses and relays and swapped them with known working relays.
It has new spark plugs in it and i have tested the coils and leads, i've reset the computer as well.
It does not show any codes, it has got a slight leak at the back of the inlet manifold but spraying any water etc around the inlet manifold while the car is running does not make it miss etc, so possibly an internal leak? It also has some smoke from the back of it if i have been reving the car, so i think this is the most likely cause.
Car doesnt blow any smoke or steam, so next on the list is dirty injectors,
any other ideas?
_homer_
Posted 16 February 2011 - 04:27 PM
_Gunmetal LH_
Posted 16 February 2011 - 04:49 PM
If it free revs fine but craps out under load then I'd put money on your leads being the problem.
Have a look under your bonnet with the engine running in the dark and give it a rev. If your leads look like plasma-ball's then replace them.
_Woodsy_
Posted 16 February 2011 - 05:50 PM
Edited by Woodsy, 16 February 2011 - 05:53 PM.
_BLACK LH_
Posted 16 February 2011 - 08:12 PM
Posted 16 February 2011 - 08:20 PM
For what it is worth just replace the leads as they can break inside when removing from plug, then this wont lead to needing to replace the coils
_robslxhatch_
Posted 16 February 2011 - 08:44 PM
Edited by robslxhatch, 16 February 2011 - 08:52 PM.
_lx5008_
Posted 16 February 2011 - 08:49 PM
_Gunmetal LH_
Posted 16 February 2011 - 11:46 PM
Smoke from the back of the manifold seems weird.
Definitely from the inlet manifold? Not the canister purge valve (black valve thingy on the drivers side on the back with 3 or 4 hoses) or the EGR valve (passenger side)?
Also check the hose that runs from the bottom of the throttle body, through the manifold to the canister purge valve. When it comes off it causes a slight miss at idle (air leak that the IAC valve cannot counteract) and could be making things worse? You probably won't notice the miss until you fix it.
If the ends have come off the hose- superglue them back on. Waste of money buying a new hose...
_Woodsy_
Posted 17 February 2011 - 10:16 AM
I'll see if i can pin point the smoke to that small black box, I pulled the injector leads today as well as the ignition leads and the car got worse on every cylinder,
The gf's old man has a VR so i am going to borrow it and swap the coils and leads over as a whole and see if that makes any difference, cant swap the fuel flow reg over coz they are different i believe.
Edited by Woodsy, 17 February 2011 - 10:25 AM.
_Woodsy_
Posted 17 February 2011 - 12:37 PM
Posted 17 February 2011 - 12:57 PM
_robslxhatch_
Posted 17 February 2011 - 02:00 PM
did you test the fuel system with a gauge, both running and static?
and a flow test???
_Gunmetal LH_
Posted 17 February 2011 - 02:05 PM
Fuel reg could be the problem. Is the miss less obvious when the vac line is disconnected?
_Woodsy_
Posted 17 February 2011 - 02:46 PM
_Gunmetal LH_
Posted 17 February 2011 - 06:24 PM
_Woodsy_
Posted 17 February 2011 - 08:59 PM
Posted 17 February 2011 - 09:14 PM
_Woodsy_
Posted 17 February 2011 - 10:39 PM
Posted 17 February 2011 - 11:13 PM
#21
_Woodsy_
Posted 17 February 2011 - 11:43 PM
#22
Posted 18 February 2011 - 12:00 AM
#23
_Quagmire_
Posted 18 February 2011 - 02:49 AM
#24
_Woodsy_
Posted 18 February 2011 - 08:09 AM
Throttle Body looks like a Big metal thing with a hole in it Quags lol
Throttle body looks fine, its nice and clean and the butterfly is working as it should
Edited by Woodsy, 18 February 2011 - 08:12 AM.
#25
_Quagmire_
Posted 18 February 2011 - 03:20 PM
tell us all what happens
oh and not "it sprayed back up at me and i got drenched"
