Just brought this manual 5lt VR exec saturday
Car started fine first thing this morning, went down the street, came back out to the car. It started, ran for a few seconds then just stopped
It didnt cough or splutter, theres no eng light or anything. You can crank, but no fire with the raw smell of fuel after a few seconds of cranking.
Straight away, thought dizzy, leads, coil, cap and rotor button
It has a brand new dizzy in it from a previous failure of the same kind.
Pulled the cap off and the centre button looks corroded and has broken off sitting on top of the rotor button. Replaced my cap and button.
Checked my coil for spark with a screw driver touching the pin and shorting to ground. NO SPARK
Checked ignition power supply to the coil, all good at 11.9 volts.Replaced the coil with new, still no good.
Thought maybe the earth has broken to the negative of the coil, added an earth straight from battery, still no good.
Not sure how they trigger, but if i put my multi-meter accross the neg and pos of the coil i should get a voltage on crank and and ignition yeah? i dont!!!
the plug into the dizzy has been damaged and the plastic piece had come out, pushed the plug onto the terminals from inside the dizzy( thats crank angle sensor on them yeah?)
How does the immobiliser fit into this equation. Anyone got any ideas, feel free to help
JNR_ATE
Edited by JNR_ATE, 20 February 2011 - 08:17 PM.
