Front brakes dragging WB caliper
#51
Posted 07 June 2011 - 09:16 PM
If it doesn't release, I'd take another .5mm off the pads.
Good luck!
#52
_GTRXU1Rooster_
Posted 08 June 2011 - 07:40 AM
#53
Posted 08 June 2011 - 07:48 AM
edit: or the stub itself so the disc/hub isn't straight...?
Edited by 76lxhatch, 08 June 2011 - 07:49 AM.
#54
_GTRXU1Rooster_
Posted 08 June 2011 - 07:59 AM
3 calipers, with 3 different slides, new pistons, old pistons,
Gonna get a set of a mates car today, after i have tested them on his car, then fit them onto my car and see what happens then..... that should be the big indicator then I think
Clay
#55
Posted 08 June 2011 - 10:04 AM
#56
_GTRXU1Rooster_
Posted 08 June 2011 - 11:25 AM
#57
Posted 08 June 2011 - 02:07 PM
My thought was that you are damaging the caliper slides and/or piston by using them on an oddball angle while bolted up to a bent stub, then the caliper is permanently damaged and won't operate anywhere (extremely long shot I know). Perhaps bench test the new caliper prior to fitting?yeah I have been thinking that exact same thing too, the only thing wrong with the idea I have come up with is that when I took it to the brake specialists up here it was only the caliper and slide, the stub axle was not there, they just used brand new pads that they had there and then for a rotor chucked in a piece of box pipe and then hooked the hose on and tested it and they jammed up, so they were jamming when on the bench
#58
_GTRXU1Rooster_
Posted 08 June 2011 - 09:33 PM
any ideas what could make the caliper pivot rather than slide on both? bent stub axle? or rotor not square? any ideas?
Clay
#59
Posted 08 June 2011 - 10:17 PM
wobble wobble
#60
_GTRXU1Rooster_
Posted 09 June 2011 - 08:39 AM
Starting to think that its time to piss them off completely.
After spending more than i should have on the current set up, and still not working I am interested in changing to an upgrade that is going to work. Looked at the Hoppers Stoppers 290 kit however from what I can see they wont work with the 15" weld wheels. Does anyone know of an upgrade simular to the Hoppers Stoppers kit where these will fit? I dont want to change my wheels.
After rebuilding the booster, master and going thru 3 sets of calipers, 2 sets of brake hoses, I just want something that will work first time!
I would like to get a twin piston setup preferably but what have other people done and works?
Clay
#61
_GTRXU1Rooster_
Posted 10 June 2011 - 08:48 AM
#62
_Quagmire_
#63
_GTRXU1Rooster_
Posted 10 June 2011 - 05:03 PM
http://www.ebay.com....=item1c1c2c1684
try these guys
well I emailed them and they havent really told me if they will fit inside the rim or not..... so I will ask again.
Next I went and got a new stub axle, and guess what???? it is still doing it, only on the 1 side, and I have changed the stub and the calipers..... kinda outta ideas now
#64
_GTRXU1Rooster_
Posted 24 June 2011 - 07:31 AM
all I can think of is that 1 set of the WB calipers, the piston was cocking off to the side when it was coming out, and the other set was pivoting on one of the pins. now everything is sorted, as far as I can tell.
Cheers for everyones help
Clay
#65
Posted 24 June 2011 - 07:53 AM
#66
_GTRXU1Rooster_
Posted 24 June 2011 - 08:16 AM
Clay
