Roller Rockers
Posted 13 May 2006 - 07:03 PM
Cheers Matt
#2 _CHOPPER_
Posted 13 May 2006 - 09:16 PM
#3 _MAWLER_
Posted 14 May 2006 - 03:22 PM
Posted 14 May 2006 - 05:01 PM
Thanks Matt
#5 _[BOTTLEDUP]_
Posted 14 May 2006 - 06:31 PM
As a general rule of thumb Street Terra's are good for 0.550" lift, 6500rpm and 300lb spring pressure. Any more than this and you'd be best looking at Yella Terras
Posted 14 May 2006 - 08:25 PM
also is that a good price?
Cheers Matt
#7 _CHOPPER_
Posted 14 May 2006 - 09:42 PM
#8 _LJ308injected_
Posted 15 May 2006 - 05:00 PM
regards: Steve
#9 _Sammy_
Posted 16 May 2006 - 12:52 PM
these are what i would suggest, they are the adjustable type which bolt straight onto any stock 202 head.
they are easy to adjust and reasonably priced!
#10 _CHOPPER_
Posted 16 May 2006 - 07:24 PM
Posted 16 May 2006 - 08:12 PM
#12 _Sammy_
Posted 17 May 2006 - 12:52 PM
as far as what the rocker part number is im not sure as YT's website no longer has any useful information on it.
Edited by Sammy, 17 May 2006 - 12:54 PM.
Posted 17 May 2006 - 07:02 PM
Posted 18 May 2006 - 11:57 AM
This is a common misconception, that the fixed type rocker gear was used because the hydraulic lifters will take up any lash. Fixed rocker gear was only used to save time on the production line. Everything is pre-calculated so that the clearances will work just right, in a new assembly.
That's fine if everything is new & to exact factory specs. But when you are building up a motor out of bits & pieces, you need to check the valve lash & adjust it if necessary. If you have fixed rocker gear, you have to grind down the posts down or shim them up. If the gear is adjustable then it's easy.
This is why you hear so many engines with noisy tappets, most of these cars have their valve lash set wrongly. An hydraulic lifter can only do so much, if it's working too close to one end of its internal travel, you will have dramas.
Think about it. If you are building up a new engine, using a different cam, lifters, head gasket, deck height & of course, the head has been fully serviced & faced, then the total lash is going to be different to how it was when it left the factory. Most guys just screw on the fixed rocker gear, which in some cases has its own wear issues, & they think it will be OK. Fact is, most of the tappets will either too far down or too loose (or a combination of both).
Even if you do a simple head service on an otherwise stock original motor, by the time the valves are ground & the head is faced, & then get the head back on the block, with a new (different) gasket, the tappet clearances will be totally different to original.
This is the main reason why most guys used to use the older style 149/161/179/186 heads with the factory adjustable rockers, when rebuilding 173s & 202s. Even Harry Firth used the adjustable (186) rocker gear, as factory standard, on the 202 XU-1, just think how many times their motors were stripped down & rebuilt.
Dr Terry.
#15 _sunburst_metalic_
Posted 18 May 2006 - 01:20 PM
#16 _sunburst_metalic_
Posted 18 May 2006 - 01:22 PM
Posted 18 May 2006 - 01:58 PM
I was told that the ones I was quoted on were to suit bolt on style 202 head and that each group of two rockers were joined together by a shaft so no guide plates required.
Cheers Matt
Posted 18 May 2006 - 02:51 PM
The ST2030 are fixed & mounted in the same fashion as stock 202 lifters, i.e. in pairs & no adjustment, so there's no great advantage in fitting them.
The ST2031, to my knowledge are basically 186 style roller rockers, so they fit & adjust the same as a 186 set-up. The expense here is you will need to have the head off the car, to be machined for studs & guide-plates. The advantage is that your rocker gear is now adjustable.
The YT5007 (pictured) bolt in place of the stock 202 rocker gear, so no machining is required & you have fully adjustable rocker gear.
I would go for the YT5007.
Dr Terry.
Posted 18 May 2006 - 06:16 PM
Cheers Matt
#20 _CHOPPER_
Posted 18 May 2006 - 08:10 PM
The YT 5007 is for the 186 type head with studs and adjustable rockers.
#21
Posted 19 May 2006 - 01:28 AM
Thanks Matt
#22
Posted 19 May 2006 - 10:12 AM
Sorry, CHOPPER, now I'm confused.
I was basing my usage of the YT5007 part number on YOUR comment on the rockers pictured.
The head was a 202 (i.e. no studs) & the adjustment is obviously at the pushrod end of the rocker. Aren't these the ones required, regardless of theIR part number.
Why would you need an adjustment screw on a rocker arm that adjustment available at the studs.
Dr Terry.
#23 _Sammy_
Posted 19 May 2006 - 12:18 PM
the ones in the picture i posted previously are ST2031 - Street Terra, shaft mounted bolt on ADJUSTABLE (via pushrod end of rocker).
the ST2030 is a NON adjustable version of the ST2031 - can't see any reason why you'd want this one.
the YT5007 is a Yella Terra rocker, not a street terror, its designed to be stronger, race type use, and is a 3/8 stud mounted rocker, which would slot straight onto a 186 head, but would need 202 head to have machining and fitting of 3/8 screw in studs and guide plates.
there is also street terror versions of the YT5007 which are screw in stud mounted and they are ST2007 - 3/8 and ST2008- 7/16.
if you want rockers to suit a stock 202 head, then get ST2031, if you want rockers to suit a 202 head with screw in studs or a 186 head then use ST2007 ... i doubt for any street motor you'd need the YT versions ......
#24 _CHOPPER_
Posted 19 May 2006 - 10:05 PM
#25
Posted 19 May 2006 - 10:22 PM
Cheers Matt
