Hi All, I am building a bottom end for my Torrie using a Blue Bottom end and red motor top end, my top end is all XU-1 and sorted, the bottom end will be Blue motor with ACL race pistons, any ideas for the build I have a $2000 dollar budget and i already have the short motor.
Bottom End
_sunburst_metalic_
, May 17 2006 11:27 AM
2 replies to this topic
#1 _sunburst_metalic_
Posted 17 May 2006 - 11:27 AM
#2 _dave720gtr_
Posted 17 May 2006 - 05:47 PM
$2000 grand! huuummm; you should buy the full larry perlins ACL race kit
Once you know witch sizes the bore has to go and crank shalf will need ginding
say 10/10 if it standed then order the kit in your required sizes
there about $500 ^$600for the kit
camshalft i think 35/75 are nice for the street, Keep costs down hyd will do fine
with good hyd anti pump up liffters .say $220
machining costs!?acid barth, deck block?.bore+hone,grinnd crank, fitting of cam bearings/ fitting pistons to rods .resize rods ? it starts two add up quick! $ 500
then you could buy a hi vov oil pump new water pump ect " were do you want to stop your $2000 runs out quick !
dave.......
dave.......
#3 _1QUICK LJ_
Posted 17 May 2006 - 07:18 PM
agree with dave720gtr ,except for the anti pumpup lifters they are a load of bullsh1t,std lifters are fine just make sure you run the right pressure valve springs and lifter pump up wont be an issue.
