Hi, I have 2 questions:
- is there any difference between a LH and a UC steering rack? I have a an LH which apparently has a UC front end, and I need to replace the rack. How can I tell if it needs a UC steering rack or not?
- How much would it cost to reco the existing rack? I am thinking that I might just get one from the wreckers (it might be cheaper).
Thanks!
LH-UC Steering rack
_LHoon_
, Nov 28 2005 09:25 PM
7 replies to this topic
#1 _LHoon_
Posted 28 November 2005 - 09:25 PM
#2 _UCV80_
Posted 28 November 2005 - 10:04 PM
there basically the same, i run a lh rack on my uc.
only difference is the bushes or washers to bolt to k frame i think...
unsure how much recoing costs
-nathan
-nathan
#3 _LHoon_
Posted 29 November 2005 - 05:45 PM
Cool thanks!
Why do you run a LH rack on your UC?
#4 _ChiaLX_
Posted 29 November 2005 - 07:16 PM
from memory a u.c rack mounts directly to the sub frame with an alloy bush and i think it also has a higher turn ratio than an lh.
to reco i think you are up for about $160-$200 last i heard , probably depends on where you go
#5 _jimjet61_
Posted 02 December 2005 - 03:22 PM
Where are u located as I have a spare sitting down the shed you can have.
#6 _LHoon_
Posted 13 December 2005 - 12:21 PM
Thanks, but I'm in Melbourne. I just went and bought a (secondhand) rack from the wreckers on the weekend for $60. It seems ok.Where are u located as I have a spare sitting down the shed you can have.
#7 _LX CHAMOIS HATCH_
Posted 03 January 2006 - 01:41 PM
racks are about the $175 mark, exchange. in NSW anyways
#8 _Flamenco_
Posted 05 January 2006 - 09:22 PM
Just on the topic of 'higher turn ratios' does anyone have the casting number (or the part number) I'd find on a rack for minimum turns lock to lock?
