gday everyone,
my clutch went the other day, pushed it in to find it was really soft, there was still a tiny bit left but it soon went completely. i removed the slave cylinder and took it apart to find that the inside of the cylinder was scratched up and full of grey guey shit. i bought a new slave and chucked it in, gave it a bleed, clutch pedal stiffened right up like normal, all sweet untill i took her for a drive, the gears were only engaging when the pedal was almost all the way out. i went for a drive anyway to learn that the clutch is slipping like crazy. does the clutch need adjusting? or is it screwed and am i looking at a full clutch job??
cheers aka
hydaulic clutch
_aka5000_
, May 18 2006 02:51 PM
4 replies to this topic
#1 _aka5000_
Posted 18 May 2006 - 02:51 PM
Posted 18 May 2006 - 06:03 PM
Sounds like the adjusment of the slave cylinder pushrod to me.
If this is a dellow or CRS setup, they have adjusments at both the pedal and slave cylinder end.
M@
M@
#3 _aka5000_
Posted 18 May 2006 - 09:25 PM
which way do i adjust the nut on the slave pushrod? towards the front or rear of the car?
#4 _Hotrodder_
Posted 19 May 2006 - 12:26 AM
Adjusting the slave pushrod so its shorter should give you the result youre after, as it sounds like the pressure plate is not fully engaging. The pushrod should be seating comfortably between the fork and slave cyl and not pushing the fork in at all.
#5 _aka5000_
Posted 19 May 2006 - 01:19 PM
ive adjusted the pushrod so it sits nicley between the fork and the slave with a couple mm play, the clutch is still slipping tho..
