what sort of diff for a lx
#1 _shane__31_
Posted 18 May 2006 - 06:55 PM
i have a lx with a 308 in it.
it has just a standard 3.36 banjo but it has got a really bad wine once you got up to like the 80km mark its bad
i think i have to change the diff but i dont know what will hold up in the long run
i have been told a lot of different thing by mates but i dont what what the best
i have been told either a ford 9inch, salsbery or a stock vn 5.0 lsd but i dont know what will be the most valubale
if any one can give4 me a help thanks
#2 _CHOPPER_
Posted 18 May 2006 - 08:22 PM
#3 _Lostit_
Posted 18 May 2006 - 09:11 PM
Denis
#4 _Loki_
Posted 18 May 2006 - 09:19 PM
It's whined like shit at 100kph for the last 5-6+ years and copped abuse behind the shitty 202.
It's still turning the wheels so.... Maybe my idea of abuse isn't much at all
I'd just turn the stereo up or listen to the musical melody of 8 ground thumping cylinders.
Edited by Loki, 18 May 2006 - 09:23 PM.
#5 _shane__31_
Posted 18 May 2006 - 11:29 PM
#6 _Hotrodder_
Posted 19 May 2006 - 12:20 AM
They are almost the correct width too, and be warned that the VN -> diffs are 50mm wider, unless you are lucky enough to find either a VN groupA or SV5000 diff which are 50mm narrower than a standard VN -> diff.
Other options?
1. UC torana salisbury diff if you can find one,
2. 9inch conversion if you can afford one,
3. Ive seen HQ/Z diffs shortened that also fit into the torry which is also a reasonably cheap conversion.
4. series 1 Volvo diff. Dont laugh, they are close to the correct width, tuff as nails, disc brakes and torana stud patern. Again Geelong diffs can do the mounts for you.
#7 _LX8VD69_
Posted 19 May 2006 - 08:22 AM
#8 _MYLJ_
Posted 19 May 2006 - 09:32 AM
V8 VB to VL diffs are the large sailsbury and would be my recommendation for your application(after conversion ), the nine inch is also a good option particularly if you intend to up the horsepower later on.
#9 _The Baron_
Posted 19 May 2006 - 11:53 AM
Unless you have the A9X floor pan you can not put the UC diff housing into your LX. Which as said above is no stronger.
Maybe if you are cash strapped, get the existing centre overhauled if it wont pass the road worthy.
Save your bucks and stay tuned on this forum as you may get the opportunity to buy a second hand bigger diff from some one here.
Good luck
#10 _shane__31_
Posted 19 May 2006 - 05:10 PM
thanks guys
#11 _Oldn64_
Posted 19 May 2006 - 06:36 PM
#12 _CHOPPER_
Posted 19 May 2006 - 10:35 PM
I have a banjo 3.08:1 pinion, crownwheel and hemisphere you can have for free. It's not in a housing. I'm in Melbourne.that sounds like my best bet at the moment try fix the back lash see if that fixes it and just hold off till someone has a decent one for sale
thanks guys
#13 _Oldn64_
Posted 20 May 2006 - 03:36 AM
anothere thing to point out is that diff whine does not just come from backlash, due to the age of teh diffs now and the fact that no one seems to care there will be alot of wear in these setups. this is why the "banjo is weak as mate" not that the diffs are bad/weak. So you might find the backlash spot on and the issue lying in another part of the diff... bearings, tooth wear, pinion loading... etc etcthat sounds like my best bet at the moment try fix the back lash see if that fixes it and just hold off till someone has a decent one for sale
thanks guys
#14 _shane__31_
Posted 20 May 2006 - 08:30 AM
#15 _CHOPPER_
Posted 20 May 2006 - 11:39 AM
#16 _shane__31_
Posted 20 May 2006 - 06:32 PM
Posted 22 May 2006 - 03:21 PM
cheers torrietree
#18 _moot_
Posted 22 May 2006 - 03:43 PM
if you use a vl diff,get a turbo or v8 one as they are 4 pin 28 spline,vl 6cyl diffs are 2 pin 25 spline.
you can also interchange ratios between the borgwarner diffs.
vl v8 3.08
vl turbo 3.45
skyline auto 3.7
pintara manual 3.89
pintara auto 4.11
all crown wheel an pinions are the same strength. i bought a vl v8 diff for my vk and also bought a auto pintara diff to get the 4.11's.at $70 for the pitara diff its good value.
also a hint,vl v8 diffs are heaps cheaper than vl turbo ones and there the same thing besides from ratio.
also if you plan to mini spool it,get a centre that is not lsd
Posted 22 May 2006 - 04:41 PM
#20 _CHOPPER_
Posted 22 May 2006 - 06:48 PM
#21 _moot_
Posted 22 May 2006 - 08:34 PM
#22 _shane__31_
Posted 22 May 2006 - 08:56 PM
#23 _jennay_
Posted 22 May 2006 - 09:23 PM
#24 _CHOPPER_
Posted 22 May 2006 - 09:35 PM
LX rear track is 54" or 1371.6 MM. VK rear track is 1414 MM. Unless it had a BW diff, then the rear track is 1440 MM.
Actual diff width from BUF ( bolt up face ) to BUF is:
LX: 56.5" or 1435.1 MM
VK: 1500 MM or 1526 if a BW is fitted.
#25 _shane__31_
Posted 30 May 2006 - 10:56 PM
i think it will do for the roady then save my money till i put in a 3.08 lsd im thinking of a 5.0 vn wait for the money then it may happen or something along those lines
