Standard Stromber Carby help
#1 _Swampy_
Posted 19 May 2006 - 02:55 PM
I cleaned the carby on my red 173 engine on a UC. Now, it doesn't idle properly. It's very rough and is liable to stall. The car is dual fuel and I run mainly on gas. I'm thinking in my ignorant way that I may have screwed up somehow an idle needle? Is that right? What could I look at? I had bought a kit but almost nothing matched so I presume it was the wrong kit.
Any ideas?
#2 _Oldn64_
Posted 19 May 2006 - 04:07 PM
#3 _Swampy_
Posted 19 May 2006 - 04:26 PM
#4 _Oldn64_
Posted 19 May 2006 - 06:53 PM
#5 _Swampy_
Posted 19 May 2006 - 06:55 PM
#6 _Oldn64_
Posted 19 May 2006 - 07:02 PM
Cannot remember how your gas setup is done or how you choke is done, if it acts on a secondary TB and not as a butterfly choke then yes all it wqill do is increase the throttle position. Is it better when warm or worse?hmm...it was about 900RPM, but I'd have to check that. It dies even with the choke out all the way on Gas, it only increases the Revs as far as I'm aware on Gas.
#7 _Swampy_
Posted 19 May 2006 - 07:13 PM
#8 _purpleLC_
Posted 19 May 2006 - 08:13 PM
Lift the top off the carby and if its the early strommy the brass idle jet unscrews- its in the middle. If it is the later carb the alloy idle jet just drops in.
Take the idle jet out and clear the passages with compressed air.
If this dosent fix the problem then maybe the gasket below the carby body is sucking air.
Cheers Louie
#9 _Swampy_
Posted 21 May 2006 - 06:52 PM
Posted 21 May 2006 - 07:00 PM
I suspect it will depend solely on your LPG Mixer... provided you use one.Is there a way to 'richen' up the gas mixture?
#11 _CHOPPER_
Posted 21 May 2006 - 09:00 PM
Posted 21 May 2006 - 11:00 PM
1) Complex converter/ Simple mixer
2) Simple converter/Complex mixer
Basically either the converter or the mixer is the controlling piece....Chopper it sounds like you have a complex converter...mine is a simple one..all my adjustments are done on the mixer.
#13 _CHOPPER_
Posted 21 May 2006 - 11:03 PM
#14 _devilsadvocate_
Posted 22 May 2006 - 07:38 AM
#15 _Swampy_
Posted 22 May 2006 - 03:44 PM
When I went to the school in it it kept stalling on me. I'm at a total loss now. It ran well when the engine was warm after going down the freeway, it sat for about 3/4 hour then I picked up my daughter. That's the only difference.
What else do I need to look at?
#16 _Oldn64_
Posted 23 May 2006 - 12:48 AM
#17 _Swampy_
Posted 23 May 2006 - 02:23 PM
#18 _CHOPPER_
Posted 23 May 2006 - 06:59 PM
#19 _Swampy_
Posted 25 May 2006 - 07:00 PM
Also, it tends to 'miss' at times. My question at this stage, since I'm only fiddling, do I take it in to a local Holden dealership to be looked at, tuned up and serviced? Would that help? It doesn't feel like the Gas is stopping for any reason.
#20 _Oldn64_
Posted 25 May 2006 - 07:06 PM
PS: Make sure the airfilter is sealling correctly. and extra gas after the mixture will make it lean out too...
#21 _Swampy_
Posted 25 May 2006 - 07:08 PM
#22 _Oldn64_
Posted 25 May 2006 - 07:14 PM
Give the man a quepee doll...The only thing I can find for enriching the mix is a large bolt nderneath the air filter where the gas hose joins the air filter. Would that be it?
#23 _Swampy_
Posted 25 May 2006 - 07:15 PM
#24 _Swampy_
Posted 26 May 2006 - 03:13 PM
