TerrA LX those where the second set of rims that I had on the SS back in about 1980. From memory we called them Magnums and I had 14x8 and 14x7 with good old BFG Radial TA's (265/245 combo). Memories and ownership of them and Hotwires. Back then 15' rims where the 20" rims of the era. The Lamborghini
Countach had 15's in a 345/35/15 that was the monster tyre at the time.
Jeff very interesting you got some good stuff going on. Kludos for being so far from the Torana's homeland and yet thru innovation and adaption loading it full of goodies. Be nice to see a down shot over the flare to show how far out you sat the 315. I have not had to move the shocks for a 315 but the 355's need the remodel on the chassis as shown (along with shock relocation). All guards are heavily cut away and reshaped for max tyre clearance including shaping the lip of the flare (with added strengthening). You can load two OS big boys in the back with no scraping. With the low rear angle its hard to see the positioning. What is your max flare to flare width? Can't remember the measurement off the top of my head but I think it was around 73" - 74". I will check that as they are factory fitted genuine GMH A9X flares not reproductions or copies.
Not sure on your tyre spec but I take it you use a 35 not a 40 profile in the 265?
Using a 265/35 gives you a 25.3" high vs 26.3" high for a 265/40 profile. The 315 are 25.7" high the 355's are 25.9" high. Wait till you got the 355s, you will have that cutting wheel on the grinder going flat out .....I will make them fit ..... LOL
Edited by LXSS350, 06 September 2011 - 06:23 AM.
