Can anybody tell me what distributor this is????
11 replies to this topic
#1 mrlctorana
mrlctorana
  • 572 posts
Posted 22 May 2006 - 06:22 PM
Hey Guys, a mate asked if I could find out exactly what this Distributor is and how it is wired up. It is to suit a 350 chev and has a built in coil with 3 wires coming from it, a red, a Black and a white. I know nothing about it so I can't help him, if you need more photos just let me know.
Here's Some pictures.....
Thanks Guys
Les
#2 _dave720gtr_
_dave720gtr_
Posted 22 May 2006 - 06:31 PM
that is what thay call a" HEI " Dizzy :spoton:
red power
black earth
white taco i think?
Edited by dave720gtr, 22 May 2006 - 06:34 PM.
#3 mrlctorana
mrlctorana
  • 572 posts
Posted 22 May 2006 - 06:33 PM
Ok Thanks Dave, Any idea how to wire the thing up???
Les
#4 _dave720gtr_
_dave720gtr_
Posted 22 May 2006 - 06:41 PM
Its been a while: but there very basic to wire up thats the beauty of them!
#5 _[2_FLY]_
_[2_FLY]_
Posted 22 May 2006 - 07:05 PM
These dissy`s arent to be underated by any means we run a stock HEI on our 600hp+ 400 chev sprint boat
#6 _[BOTTLEDUP]_
_[BOTTLEDUP]_
Posted 22 May 2006 - 07:32 PM
Les
Ummm :blink:
Red = 12V ignition power
Black = Earth
White = Tach output
Any further questions? ;)
#7 mrlctorana
mrlctorana
  • 572 posts
Posted 22 May 2006 - 10:00 PM
Cheers Guys, Thanks BOTTLEDUP, No further questions Your honour, All seems to easy!!!!
Les
#8 _devilsadvocate_
_devilsadvocate_
Posted 22 May 2006 - 11:22 PM
I think you need at least one wire going to the -ve of the coil, perhaps the white?
Can see a pink and green wire(these are the bosch colours for +ve and -ve of coil), is red connected to pink and green to white?
Earth wire?
In the bosch hei commodore ignition the dizzy to block connection makes the earth.
Id check for dc resistance with a multimeter between dizzy body and black wire, if close enough to zero, its an earth wire.
Edited by devilsadvocate, 22 May 2006 - 11:29 PM.
#9 _Yella SLuR_
_Yella SLuR_
Posted 22 May 2006 - 11:37 PM
Red Positive coil
White Negative coil
Black - Distributor/Engine body earth
Note that it reverts to bosche colour wires once through the housing to the module.
#10 _devilsadvocate_
_devilsadvocate_
Posted 22 May 2006 - 11:45 PM
Not sure so sure of my post ^ now, does this dizzy have an inbuilt coil?
Edited by devilsadvocate, 22 May 2006 - 11:47 PM.
#11 _dave720gtr_
_dave720gtr_
Posted 23 May 2006 - 06:05 AM
thats right devil in built coil :spoton:
#12 mrlctorana
mrlctorana
  • 572 posts
Posted 23 May 2006 - 06:12 PM
Yep, Has in built coil. I checked for resistance between body and black wire, No resistance, so Black has to be the earth. The red and white wires go into the dizzy and to a black module which has a green and a pink wire coming out the other side of it.
The clip that the three wires (Red, Black, White) out out the side of the dizzy go to looks like it clips onto the lugs that are on the distributor cap, which go to the coil. There are three wire coming out of the coil, a Yellow which has two lugs to connect to, a Red which has two lugs to connect to and a Black which has one lug.
If that is where the clip goes which i assume it is, there is two lugs left to connect which are from the coil, a yellow and a red, Guessing red would have to be a switched 12v from the ignition switch, Yellow im guessing goes to tacho. I reckon the dizzy earths through the engine block, and the black wire from the dizzy provides the earth for the coil. Does this sound right???
Heres some pics:
Les
