Nine-inch, or not to nine-inch
Posted 05 September 2011 - 12:59 PM
I am in a bit of a dilemma and was interested in people's thoughts to help make my decision.
I am building a four-door LX (with flares), and bought a Torana-friendly nine-inch for it 18mths or so ago. It is 28-spline, standard width, single-legger, Torana mounts and commo disc brakes, which also means in this case Commo stud pattern. Later, and knowing more, I bought a Hoppers Stoppers kit for the front brakes, and went HQ stud pattern to open up the wheel choices available. So I now need to either get new axles with HQ stud pattern for the nine-inch or have the axles re-drilled to HQ (of dubious legality), both costing more cash, plus I need brakelines made up, new axle bearings and a couple of other bits and pieces to get it totally ready.
OR, I could sell it, and use the money to buy a recoed VN-VS LSD Commodore diff with brakes and handbrake cables etc, get the mounts taken off the original Torana diff I still have and fitted up, new axles with HQ stud pattern and have it ready to go well within the money I make from the sale.
The car will run a standard-ish 304 and T5 to begin with, and I won't be dragging it or doing burn-outs (I know, booo), so am thinking the weight and cost of a nine-inch are probably not worth it. I really want a slippery center, too. Given the cost savings, and that I drive with a reasonable bit of mechanical sympathy, I reckon this might be the way to go. Thoughts? Any other options to consider (other BWs such as Skyline diffs would work too, obviously)? Or should I just keep the thing?
cheers,
Posted 05 September 2011 - 01:19 PM
Dont even consider him.
Posted 05 September 2011 - 01:28 PM
Edited by myss427, 05 September 2011 - 01:29 PM.
Posted 05 September 2011 - 01:30 PM
If you want maximum traction at both tyres then you will need a locking diff or KAAZ instead of an LSD.
Posted 05 September 2011 - 02:44 PM
As it will be a street-driven car and I like going around corners, I'm not interested in mini-spools, and thats why I was after a LSD center option that won't mean spending another $1000 on a 9-inch LSD center, plus axles, etc, etc.
Mmmm. Better make a call soon! Thanks for the feedback.
Posted 05 September 2011 - 03:58 PM
The cheapest option for the 9" would be to fit something like the powertrax locker in the opecenterre that you have. Next option would probably be a rebuilt LSD. After that you have Truetrac and Detroit lockers. The powertrax and Detroit lockers will provide the most traction but are also noisy when cornering. The Truetrac and LSD will provide considerably less traction.
Edited by ls2lxhatch, 05 September 2011 - 04:10 PM.
Posted 05 September 2011 - 04:04 PM
Posted 05 September 2011 - 04:10 PM
Posted 05 September 2011 - 08:50 PM
Aarrgggghhh. I'll sleep on this one. Thanks again for the info.
Posted 05 September 2011 - 09:50 PM
Posted 06 September 2011 - 09:23 AM
#12 _nial8r_
Posted 06 September 2011 - 01:37 PM
#13 _LS1 Hatch_
Posted 06 September 2011 - 02:11 PM
Posted 06 September 2011 - 03:17 PM
Posted 06 September 2011 - 05:33 PM
Posted 06 September 2011 - 05:38 PM
Posted 06 September 2011 - 07:09 PM
The BW M78 is a good choice for the Torana but by the time the LSD has been replaced with something decent it is not a particulary cheap option for a street car.
Posted 06 September 2011 - 07:20 PM
Get the axle lengths checked and you might be lucky enough to just use some HQ Sailbury axles straight in
Or at worst a shorten
Depends on what length your diff is set up too
And you said BW Commy diff... all good idea but you still have to shorten that
So you will be out of pocket compared to doing the 9" you alredy have
If you had nothing and were starting from scratch I'd go the BW myself though
They can be made strong , cheapish and lighter
But thats a personal choice thing on my part
Posted 06 September 2011 - 07:36 PM
I am not aware of an option to replace the cast iron center on the BW M78.
Edited by ls2lxhatch, 06 September 2011 - 07:36 PM.
#20 _Bomber Watson_
Posted 06 September 2011 - 07:48 PM
Posted 06 September 2011 - 09:14 PM
Sure you can use a sheel metal housing and centre... but thats not the equation here in the original question
#22
Posted 06 September 2011 - 09:16 PM
I don't want commo stud pattern as per the comments above. I thought I did, until I searched options to suit flares, and found them a useless. I went hq pattern onthe hoppers brakes because it's the same as chev pattern and meant I could getthe whes I wanted from the US.
Good call on the Salisbury axles Dattoman, will check that out.
Rexy, I've been quoted $200 each axle... Maybe they just didn't want to do them. I'll see if I can find the $100 price, I'd be happy to pay that. Do you know of a Sydney mob who could do it for that? I'll try the usual suspects
Jeff, is there much noise from the eaton? And how is the lock/unlock action? Be worth thinking about if ok on the road.
Thanks all for your feedback.
#23
Posted 06 September 2011 - 09:35 PM
The Truetrac will never provide equal power to the wheels. The Truetrac is a good choice for a street car but it will not provide the same amount of traction as a locking diff like the Eaton Detroit Locker.
#24
Posted 06 September 2011 - 09:38 PM
Geeze I just learnt alot about diffs...
#25
Posted 06 September 2011 - 09:51 PM
Edited by WHALEOILBEEFHOOKED, 06 September 2011 - 09:51 PM.
