Driving with Roll cage on the street...options?
#1 _m7hs_
Posted 07 September 2011 - 01:41 PM
Have a heard a lot of second hand info and just want to know how I go about keeping the roll cage in on the street and using the back.
Regards
Michael
#2 _m7hs_
Posted 07 September 2011 - 01:44 PM
Posted 07 September 2011 - 02:04 PM
Must be padded
And you can no longer carry rear seat passengers
Best get it clarified with rego
I'm sure Andy will refer you to a similar thread recently and show you the NCOP page relating to cages
So that info will help
But you need to get the OK from the Dept regardless of what we say
#4 _mumbo_
Posted 07 September 2011 - 02:43 PM
So if your in WA and your car is quicker than 10s you are screwed.
Posted 07 September 2011 - 03:48 PM
I currently have an unregistered race car, was a log booked , a class registered car on CAMS rally plates.
The whole system is screwed with the department of transport, the pits , cams, and the police all having their own interpretration of their own recent agreement in regards to abolishing the old b class system.
Farknows.
but best wishes all the same
#6 _m7hs_
Posted 07 September 2011 - 04:21 PM
Half cage only no back seat and no side intrusion bar on the street and ANDRA will let you do 10s with a half cage and bolt in intrusion.
Yeah there's a sweet spot from 11 - 10's car, you can have bolt in side intrusion.
The car is registered and has the cage installed, but basically your saying if i want passengers in the back seat, I have to go half cage? Does that include removing the taxi bar?
Probably best i get the fine print from rego mob so I am not court out.
Posted 07 September 2011 - 04:35 PM
The individually built cage rules start on page 41 of the NCOP7 Section_LK_Seating_and_Occupant_Protection_1Jan2011_v2.pdf
Six-point roll-cages that have supports running down the A pillars and B pillars, and braces running to the rear are not acceptable for normal road use.
A four point cage or four point cage that converts to a six point at the track can be approved however it can only be driven on the street in the four point configuration.
The main stumbling block for the Torana would be the head space requirements for the rear passengers on pg 43.
Posted 07 September 2011 - 04:59 PM
#9 _m7hs_
Posted 07 September 2011 - 05:25 PM
Ls2 cheers for the info. I will have a read.
Thanks all for your help.
#10 _mumbo_
Posted 08 September 2011 - 10:06 AM
No if you have a half cage you need to remove rear seat and be licenced as a 2 seater.
#11 _m7hs_
Posted 08 September 2011 - 05:22 PM
Mumbo
getting really confused here. So there is no way I can make this car a 5 seater unless i remove all of the cage, is that what you are saying?
Posted 08 September 2011 - 07:15 PM
If you can not build a cage in the Torana with the required head clearance for passengers then you can not have passengers.
#13 _mumbo_
Posted 09 September 2011 - 10:14 AM
Mumbo
Thats it with normal rego no cage if you want to use back seat.
I dont know the rules when it comes to B grade rego but i do think you have to have a CAMS licence and i dont think they would let you have a back seat either.
