help me build a 500+hp sbc
26 replies to this topic
#1 _chev400_
_chev400_
Posted 11 September 2011 - 11:53 AM
hi all, i'm looking to build a 350 stroked to 383 or higher, i know by far the 383 is the most common, i want some opinions on what combo's for internals and type of aluminium heads to get me pushing up over 500+ fly hp, does anyone have or anyone heard of some combo's they have that got them these numbers???, i know a lot depends on the heads, cam, manifold etc, and i have my own ideas on some big brands to get, but would like to see some proven facts and motors with actual combo's being used before i start making purchuses, i have the base which is a 4 bolt std bore block, behind it will be a glide with a brake and a full spooled, 31 splined 9 inch, aiming for 10's down the 1/4, all help is greatly appreciated :)
#2 ACJ
ACJ
  • 197 posts
  • Name:adam
  • Car:LH
Posted 11 September 2011 - 05:56 PM
Hi chev400
Not a SBC but some of my thoughts.
I have just put together a Holden 355 hoping for 500 + HP.
I look at other car (in magazines) and if they all had torque power manifold and making over 500 HP it must be a good stare.
I wrote emails to companies like scat and crane cams, they are very helpful and this is some of there replies.
The best selection for your application is the Crane F-288 #883691 cam. This grind performs very will in 355 Holden's and has potential to make 500+ HP if the heads flow well.Attached is the cam card with all the relevant specs. Regards Jim Ioannidis Crane Technologies.
The 2-ICR5700-7/16 would be just fine and be the lighter of the two. The weight about 590grams, and will hold up to 500hp and 7000rpm.
If I could be of any more assistance please feel free to contact me by email or by phone at (310) 370-5501 and dial extension 121.
Thank you, Alex Gonzalez SCAT Enterprises.
Also bigger is not always better. I was very weight conscious with rods and pistons. Most people would just put I beam rod in but if you don�t need it the weight is just more stress especially with pistons.
To get the most out of the bits you get is very important, like making sure the manifold ports line up to your heads propel.
You are on the write track; gather all the information you can.
#3 _Liam_
_Liam_
Posted 11 September 2011 - 06:33 PM
My prior plans for a 500+HP 383 went wayward... This is what we had though.
350 4 bolt block.
Scat series 9000 rotating assembly kit, (4340 Crank, I beam con rods, Clevite bearings, SRP Forged Pistons with 15cc dish, allowing for valve recess)
Running bout 11:1 compression.
AFR 220cc heads with 65cc intakes.
Crane Gold roller rockers with guides 1.6:1 ratio
Roller lifters
Cam, Hydraulic roller, ground at round about 250 @ 50 thou, max lift at 380 thou.
Edelbrock Single plain Victor manifold.
Quickfuel or Holley about 900 cfm...
I was hopeful of at least 500 HP, costing about 8.5K
#4 _wombat_
_wombat_
Posted 11 September 2011 - 07:07 PM
depends on how deep your wallet is,we have a 358 that does 667hp on dyno(7.95@164mph in 800kg car) with single 750 holley cast iron 23 deg heads,
but its a big buck thing with 6.2" honda journal rods/light wieght crank and 50mm roller mounted cam,titanium every thing in the valve gear etc.
as they said in mad max speed is just a matter of how much you want to spend.
#5 _glenn l_
_glenn l_
Posted 12 September 2011 - 08:33 AM
are you running c/a wombat?
#6 _Ned Loh_
_Ned Loh_
Posted 12 September 2011 - 08:34 AM
As per previous posts - what's your budget? if you are on a tight budget I'd suggest buying David Vizards book about small blocks on a budget as a good starting point.
Given your 500hp aim, I'd also suggest that you make sure the basic prep is spot on. Coming up with a nice 'brand name' parts list is fun but will not help or save you if the blueprint isn't right.
#7 _Ned Loh_
_Ned Loh_
Posted 12 September 2011 - 08:39 AM
350 4 bolt block.
Roller lifters
Was the 8.5k parts only, or did it include machining as well?
#8 myss427
myss427
  • 1,636 posts
Posted 12 September 2011 - 08:52 AM
500 in a small block is very easy to achieve, good heads (AFR's) reasonable compression and a decent cam will make it easy. Reliability is what costs, the easiest way to get the horses is go the biggest cubes. That way you don't have to rev it so hard, why not go 400 cubes?
#9 _Liam_
_Liam_
Posted 12 September 2011 - 09:12 AM
Was for parts. Another 1-2K for machining and assembly.
Myss427:- I have had this arguement about 400's before, they aren't much more dearer than 350 blocks. Which is why we are goin that route. However the thread starter has a 350 Block already.
#10 yel327
  • 13,734 posts
Posted 12 September 2011 - 09:15 AM
These go close as a crate engine:
http://www.summitrac...arts/EDL-46213/
http://www.summitrac...rts/PAR-3832SD/
http://www.summitrac...s/NAL-12498772/
This gets what you want: http://www.summitrac...s/MLL-PS4271CT/ , you wouldn't build it for that plus freight in Australia.
Or this is the ultimate (but not a small block):
http://www.summitrac...s/NAL-19166392/
#11 _chev400_
_chev400_
Posted 12 September 2011 - 01:59 PM
thanks for the responses so far guys, but keep em coming, the more info the better
( Ned Loh ) thats precisely why ive started this thread, to get all the info i can before starting to buy anything, i'll be thinking different combo's and once i'm happy with the combo i want i'll start making dents in my wallet (although its already empty lol) oh and i'll be getting the machining done but assembling this all myself.
(myss427) the AFR's we're one of my picks as i have read plenty of good reviews about them, does anyone recommend brodix?, the reason i'm staying with a 350 is because the car i have is engineered with a 350 in it, i havent looked much into the stoker cranks yet but one of my ideas was a 408 stroker, if i setup a cood combo with a 408 i shouldnt have much trouble in succeding in my goal.
****also while on the topic of heads, i know basic knowledge like porting makes good power gain etc but can i get some light shead about some specs like all these degree* and cc's etc ? i'm very willing to learn all aspects of knowing the in's and out's of different kinds and styles of heads and what gives better flow and more power or compression etc****
(yel327) thanks for those links mate, have been looking at the summitracing site and been staring at some of their lunati lightweight cranks, as the shipping is under $400 to my door i'm very much considering getting a few parts through these guys as even with postage its still cheaper than getting them through rocket.
thanks for your help so far guys, lets keep the replys coming and lets get a nice neat little engine together :)
#12 yel327
  • 13,734 posts
Posted 12 September 2011 - 02:44 PM
I'd love that ZL-1 427 replica for my HK GTS327, but I don't want to spend that much. I already have a cast iron 454 block, crank adapter, forged 427 crank and L88 inlet manifold. All I need are some alloy heads and I have the basis of an L88 replica engine (same as ZL-1 minus the alloy block). So it'll have to do (and will be still less than 1/4 of the price of that ZL-1 replica)!
#13 _Ned Loh_
_Ned Loh_
Posted 12 September 2011 - 03:35 PM
Ok. Good that you are assembling yourself so at least you can check everything. Give written orders for machining and be specific with regard to what finish and clearances you want etc. Measure everything yourself once you get it back. You cannot trust that it is what you ordered.
Not to plug it too much (you decide if it will help you), but link to book I mentioned: http://www.summitrac...parts/SAD-SA57/
I have found some of his other books very good.
EDIT: Use a good machinist!
Edited by Ned Loh, 12 September 2011 - 03:36 PM.
#14 _Liam_
_Liam_
Posted 12 September 2011 - 05:06 PM
Stroking to a 408 requires a bit of work, Boring the block so that the cylinders are even closer than they need to be, the 383 itself will be great bang for buck.
The angle you see on Head descriptions are about the spark plug. So in this case a 23 degree head has the spark plug angled 23 degrees towards the exhaust port. The cc's have two measurements. 220cc would be the entire intake volume, where 65 cc is the volume of the combustion chamber. Obviously bigger heads for bigger engines. Brodix make good heads from what i hear as does Patriot. Ideally you want them to flow 300 cfm to make good use of it all.
Don't know much bout Lunati... SCAT are very reputable and very trustworthy. Making complete rotating assembly kits. Like this. http://www.summitrac.../SCA-1-40755BI/
Apparently stay clear of Hypereutectic pistons. May as well get Forged.
#15 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 12 September 2011 - 11:08 PM
If your going to offer advice, make sure its correct first, the degrees on chev heads actually relates to the angle of the valves in relation to the deck surface, it has nothing to do with the spark plugs
#16 rodomo
  • 18,055 posts
Posted 12 September 2011 - 11:21 PM
I don't know much about Chevs but I heard form a mate that for best results the plugs should be pointing towards mecca? :dontknow:
#17 dattoman
Posted 12 September 2011 - 11:48 PM
Best to have the plugs not pointing at the pipes
My Chev has straight plug heads when I dismantled it
Now it has angle plug alloys
#18 _Liam_
_Liam_
Posted 13 September 2011 - 05:10 PM
My mistake I thought that's what it was. Apologies to thread starter.
#19 _chev400_
_chev400_
Posted 13 September 2011 - 10:05 PM
no probs torry freak, we learn new stuff every day, but your onto the the cc part correctly im guess so you didnt give all bad advice :), so the bigger cc's the better i'm guessing?
(makka) so with the different degree type of heads, what is advantagous over others? the bigger the degrees the better? does it mean there is more clearance for the valve opening? can you get bigger compression etc?
oh and torrie, not going any shit hyper stuff mate, going forged all the way, always have done :)
#20 dattoman
Posted 13 September 2011 - 10:08 PM
Bigger head CC in the chamber lowers your comp ratio
Bigger port CC's means it can flow more air
But if they are too big or your volumetric efficiencey is low then it will bog down at lowe rpm and be a pig down low
So its a compromise if its a streeter
Changing from say 23 to 18 degree heads can make a significant difference.... but them no maifolds etc fit easily and you need specific ones not off the shelf... or custom machining
So stick with 23 deg unless your building a race engine or have a bottomless wallet
#21 _Liam_
_Liam_
Posted 13 September 2011 - 10:20 PM
Deal breaker for most. They do have aftermarket heads for Chevy's in 23, 18 and 15 degrees. 18 is better than 23, and 15 is better than 18 flow-wise. But special valvetrain gear is required to use them, and as Dattoman informs, special (expensive) manifolds ... And as mentioned expensive as hell.
#22 _chev400_
_chev400_
Posted 13 September 2011 - 10:54 PM
mmmm so i see there is a bit of a fine line between bigger cc's and compression, i'd like to stay up around 11.1 but at least 10.1 comp, i'll be port matching the heads to the manifold myself for better performance, when the time comes i might have to go speak to a head specialist to help decide what to get, as for how deep my wallet is, there is no such thing as cheap power, i wont be going overboard but i know it dont come cheap either, i'll be buying bare aluminium piece's then getting the valves, springs rockers bit by bit as i get the cash, if i dont find any bargains i know i'll be up for in access of $3000 if not more for a good set of reliable heads for piece of mind, when it comes to rebuilding engines i dont cheap out on any bits, learnt that lesson long ago, oh my poor little 2 litre cortina, had a few transplants backyard style....lol
#23 dattoman
Posted 13 September 2011 - 11:09 PM
For good off the shelf CNC ported heads I bought the Patroits
https://www.patriot-...7&cat=41&page=1
I "flow tested" about 12 different options on the desktop dyno and the 2 top performers were the Edelbrock Victor Jnr and the Patriot
The Victors had 1 more HP at RPM but lost alittle in low end torque
Sure I could have made more power... but I just wanted a torquey stump puller
I won't be turning it past 5500 anyway
Though if I was going to push it and had my cash again... I can't go past the ARAO 32 valve heads with B series stage 3 port
http://www.araoengin...es.htm#B-Series
#24 _Liam_
_Liam_
Posted 14 September 2011 - 09:39 AM
10K for heads.... Mmm wonder how many people would actually buy that.
#25 dattoman
Posted 14 September 2011 - 10:07 AM
Only those that want to go fast
Everyone knows the performance is in the heads and flow
Happy to spend huge # on the bottom end... then buy off the shelf heads
Or madly port average heads and still spend the same amount of cash
And thats top of the wazza... the ones I want are only 5500
And I know a certain big block owner that might have bought a set if he could have used his original manifolds
But since they would have to be custom he didn't
