I have 13x7 inch rims atm but i want to soon upgrade to 14x7. However, i am in a dilemma in which my current tyres are nearly bald and i cant find the rims that i want. I have Bridgestonee eagers s340 atm. What size tyre will fit on 13inch rims and also be a low-profile on the 14inch rims??
any help will be appreciated
trav
What size tyre do I use??
_trav_
, May 23 2006 07:26 PM
7 replies to this topic
#1 _trav_
Posted 23 May 2006 - 07:26 PM
#2 _ChiaLX_
Posted 23 May 2006 - 07:58 PM
Not sure what you mean here?
Are you planning on getting tyres for the 13's and them put them on 14" rims down the track? cos that wont work.
#3 _CHOPPER_
Posted 23 May 2006 - 08:10 PM
I will assume you want a 14" tyre with the same overall diameter, so as not to alter the speedo. If so, please post what size tyre you currently have. Otherwise, as ChiaLX said, you can't put a 13" tyre on a 14" rim AND inflate it.
#4 _trav_
Posted 24 May 2006 - 04:48 PM
sorry guys,
Chia you answered my question.. i was hoping that i could possibly get a 13inch tyre that, down the track, i could put onto a 14inch rim but as you said that wont work.
Thanks guys
trav
Thanks guys
trav
#5 _trav_
Posted 24 May 2006 - 04:50 PM
chopper if this helps i currently have p205/60r13 bridgestone eager s-340. What are the other possible sizes i can put on??
trav
trav
Edited by trav, 24 May 2006 - 04:51 PM.
#6 _CHOPPER_
Posted 24 May 2006 - 07:29 PM
Anything in 14" with an adequate load rating will be at least 30 MM bigger in diameter. Unless the vehicle was made before 1/1/1971. Then that gives you a lot more options. It would also help if you post what width rim you intend on using.
#7 _trav_
Posted 25 May 2006 - 02:12 PM
i intend on using a 14x7 inch rim in the future
trav
trav
#8 _Keithy's_UC_
Posted 03 June 2006 - 11:10 PM
225/60/14 is what im running on my UC, upgrading to 225/45/16 in the next 2-3 weeks... I have heaps of 14" wheels up here if you like to drive....
Keith
Keith
