Just chasing some comments on how to deal with a ticking noise that appeared today. The engine has had a new cam (Crow 5761), anti pump lifters, new pushrods ... has run really well. The service notes indicated weaker than recommended valve springs for the camshaft but did not advise replacing at this point.
Today after warming the car up for 3 minutes, then driving for another couple of minutes, it took about 15 seconds for a ticking sound to appear. I turned around and took it easy getting home but the noise is still there. It felt like it was running on 7 cylinders and backfiring.
Still had 30-40psi + oil pressure, has std oil pump
I pulled the left bank rocker cover, and noticed one of the rockers over #2 cylinder appears loose on the pushrod. Surely this is the problem? This pushrod sits lowest compared to the other cylinders ...
Am I right in thinking this a dead lifter, which means pulling the intake manifold off? The car has only done 200 easy km since the install, not including the cam run-in.
I take it that driving this car will only risk killing the (original) block, and I don't have the full tools (or expertise) to pull the manifold off and change the lifters, so is a mobile mechanic the way to go?
