Weird old Thermo Fan?
Posted 30 September 2011 - 12:58 PM
Might help date the previous build of the car if I did
#2 _The Baron_
Posted 30 September 2011 - 02:09 PM
Take it off and put it up on a shelf in the shed for display, that is all it is good for!
You can go back to the original metal engine driven fan and put up with it or install an electrical one that work.
I have the AU fan setup which is just awesome but bulky. Someone here has used a smaller one off the mondeo (I think) which fits easier.
Posted 30 September 2011 - 02:41 PM
Yeah when I re-wired the harness, Ive fitted extra wiring for a temp sensor in the manifold which will switch GND for a relay that will run a thermo fan.
Posted 30 September 2011 - 07:59 PM
Posted 30 September 2011 - 08:07 PM
Posted 30 September 2011 - 08:12 PM
Posted 30 September 2011 - 09:20 PM
Ive got one here somewhere if you want a pic for comparison.
#8 _torbirdie_
Posted 01 October 2011 - 12:23 AM
Bracket looks like from a kingswood, but they were always fitted on outside of radiator.
fan blades, looks like a couple are from a 7 blade clutch fan, others fabricated.
Original fan blades on these were like on this one:
http://www.google.co...iw=1133&bih=571
but they could warp or crack.
Id of thought the metal blades shown would be a bit heavy for that motor
Ooh, and there's a thought, Ive got two of the slim line davies craigs in the shed and a preslite(they put them on the kingswoods)+ a frame to fit two of them to a chev radiator in the shed.....
Edited by torbirdie, 01 October 2011 - 12:28 AM.
#9 _The Baron_
Posted 01 October 2011 - 02:57 PM
"The motor is a davies craig unit, same as fitted to the a9x"
The motor in hanra's photo is not the A9X one, the correct A9X one is in your link.
Posted 08 October 2011 - 03:34 PM
But awful to look at.
Posted 06 November 2011 - 03:41 PM
Posted 05 January 2012 - 02:12 PM
Edited by hanra, 05 January 2012 - 02:14 PM.
Posted 06 January 2012 - 07:38 PM
#14 _ht467_
Posted 06 January 2012 - 10:15 PM
This is the fan on one of my cars which were all the rage at the time, though you will end up with finger like that dude in Max Max 2 that tried to catch the boomerang if you get to close to it!
Posted 06 January 2012 - 11:48 PM
#16 _LS1 Hatch_
Posted 07 January 2012 - 02:32 AM
http://www.ebay.com/...=item23182c16ad
Posted 07 January 2012 - 08:04 AM
Thanks for the lead!!!
#18 _LS1 Hatch_
Posted 07 January 2012 - 09:38 AM
Posted 26 August 2012 - 07:43 PM
Posted 08 June 2022 - 09:41 AM
Not Palmer Cool..........Perma Cool. They still make 'em.
Screenshot 2022-06-08 073954.png 633.18K 3 downloads
#21
Posted 08 June 2022 - 09:50 AM
Now that Shiney has pinpointed the fan's original configuration, looks to be originally designed for the condensers you see on refrigerated trucks.
#22
Posted 08 June 2022 - 10:02 AM
I chucked it in the bin!
#23
Posted 08 June 2022 - 10:09 AM
Ive sent Perma Cool an email to see if the recognize the model number.
https://shop.perma-c...ic-Fans_c26.htm
#24
Posted 09 June 2022 - 05:57 AM
Posted 09 June 2022 - 10:31 AM
Good on them. At least they went to the trouble of having a look. I spent some time writing to the biggest Repco shops back in the early 1990's looking for the old tooling from their engineering days and all I got was the literal equivalent of blank stares back.
