Acid dipping bonnet
#1 _Eddie_
Posted 27 May 2006 - 10:14 AM
Anyone here had theirs done?
Posted 27 May 2006 - 10:34 AM
Posted 27 May 2006 - 10:43 AM
What do you mean by this rodomo?
I understand about the sealant under the bonnet, but how do you reapply it?
#4 _Eddie_
Posted 27 May 2006 - 10:54 AM
#5 _Eddie_
Posted 27 May 2006 - 12:13 PM
Posted 27 May 2006 - 12:20 PM
#7 _Pete_
Posted 27 May 2006 - 12:40 PM
I'd recommend paint stripping the topside and if they're is a need to baremetal the underside, maybe trying to find a blaster who blasts using baking soda or a similar car panel friendly abrasive. Failing that I'd go to town either with a 3M Clean 'n' Strip wheel or paint strip it carefully.
The Sealer/adhesive you'd need is just good old Black Sikaflex, there are other brands available to from Wurth etc.
Edited by Pete, 27 May 2006 - 12:41 PM.
#8 _Eddie_
Posted 27 May 2006 - 06:45 PM
#9 _Pete_
Posted 27 May 2006 - 07:03 PM
I guess you could flood enough primer in there to get some coverage and then rub out any runs prior to paint, maybe even use a flexible extension on the end of the gun to get into the tight spots.
Theres probably not too much of an isssue of the bonnet rusting away, if its lasted this long its more than likely gonna survive another 30yrs, I think there might be a chance of rust stains ruining the paint finish later on.
Maybe another option is after its dipped cut the inner skin off, prime the underside then weld a smooth sheet of steel in place so its a nice smooth show car like effect when you pop the bonnet. Like a smoothed out Hot Rod!! or like Dynosteves SMOTY LJ , might have to check underbonnet clearances but it would look awesome!!
#10 _Eddie_
Posted 28 May 2006 - 01:29 AM
Posted 28 May 2006 - 06:51 AM
#12 _Bomber Watson_
Posted 29 May 2006 - 07:45 PM
#13 _FCCOOL_
Posted 29 May 2006 - 09:57 PM
if you get it acid dipped you will need to get the paint right into the crevaces or it mightl drip orange stuff when your car gets wet.
#14 _Eddie_
Posted 31 May 2006 - 09:06 PM
Anyway that's one way, does anyone else have any others? For my way to work the product ideally would be ok to apply to bare metal, be relatively runny, and can have top coats put over it (not essential tho). Any ideas of a suitable product?
Edited by Eddie, 31 May 2006 - 09:10 PM.
#15 _Pete_
Posted 31 May 2006 - 09:34 PM
I think it would look a bit messy trying to urethane seal the entire area, some might say it would look a bit dodgy and you'd run the risk of sealing the air inside which will expand and contract with the difference in temps and most likely buldge your bonnet on a hot day, I'd just re-apply whats been stripped out to secure the skin to the inner frame.
I'm thinking i'll skin the inners of my bonnet and boot lid when I do the rebuild of my LX so its nice and smooth, I think it looks pretty nice and it really wouldn't be a hard job maybe just a little time consuming particularly all the welding and grinding but still not rocket science.
Edited by Pete, 31 May 2006 - 09:38 PM.
#16 _Eddie_
Posted 01 June 2006 - 04:20 PM
#17 _finer70_
Posted 01 June 2006 - 08:03 PM
Both are effective strippers. Acid needs to be fully and totally and fully and totally removed to prevent it continuing to work on the metal or leaving it bare for oxidation (RUST).
Caustic stripping is different. Being alkaline it is kinder to the metal and actually leaves a surface coating that if kept dry will remain rust free for 6 month.
The only treatment necessary before painting is to apply a water like phosphating compound which will form a paint friendly coating.
Applying too much sealant in an attemp to protect hard to get at areas can work against the intention you want. It may trap condensation and promote corrosion. If it were not sealed with air able to flow and keep it dry it may well be better.
Anti rust compounds and fish oil can be sprayed into these areas and keep the hungry beast (rust) at bay.
I have had two LC bodies fully caustic dipped and had NO problems with resealing joints etc. I flooded all seams with phosphating compound, let them thouroughly dry and them applied factory quantities of seam sealant compound.
As for sand blasting, you simply need to get someone who knows what he is doing. There is no reason for a panel to be damaged by sandblasting. If it is damaged it just shows the person doing the job does not know how to do it, or he is using an indusrtial sand blaster with too high a pressure. The right tool and the right tradesman will always give the right result. Trouble is finding them.
#18 _Eddie_
Posted 01 June 2006 - 09:06 PM
#19 _finer70_
Posted 02 June 2006 - 06:57 AM
