1980 UC Sunbird - Lexus 4.0l 1UZ / A350 5spd auto / GTR Skyline rear suspension.
Trial fit no 1...
A neat fit between the chassis rails with heaps of room in front, trying to keep as low and as far back as poss to minimise clashes with the brake booster and heater.
About 20mm clearance between the cam cover bolts and the chassis rails.
Sufficient room for exhaust to clear everything. The engine mount on the crossmember will go and the top suspension arm pivot will be lowered 25mm. The flexi coupling on the steering shaft will be replaced with a compact universal joint.
The flange on the chassis rail will be beaten back under to allow a little more clearance without affecting strength.
The TransDapt big block biscut mounts I have selected are very compact and stiff so will allow little movement of the engine. NVH is not a priority...
Have pulled the motor back out to remove the unneeded bits and sort the engine bay. Engine mounts are about 3 weeks away so will tackle 'Trial fit no 2' then...
1UZ / UC
_TOBES_
, May 27 2006 02:42 PM
4 replies to this topic
#1 _TOBES_
Posted 27 May 2006 - 02:42 PM
Posted 27 May 2006 - 02:48 PM
instead of beating that lip down, you should cut it and seam weld it. much meater and probably as strong if not stronger, its a farily common mod. otherwise its looking good
Edited by makka, 27 May 2006 - 02:48 PM.
#3 _conceptss_
Posted 27 May 2006 - 08:10 PM
Nice.
#4 _toddy_
Posted 28 May 2006 - 07:16 PM
Tobes
Its great to see that you are doing some thing differant with your motor choice, can you please give us some more details on what type of trans etc you are going to use.
This shall be an interesting conversion to watch
#5 _conceptss_
Posted 28 May 2006 - 08:04 PM
Not too long and you can have one of these
