is this good hp readings?
#51
Posted 04 December 2011 - 07:37 AM
#52
Posted 04 December 2011 - 08:29 AM
Got to love everyones belief in giant easy dyno horsepower.No, no, no too much. If you are paying the money you should get what you pay for. Old school red heads on a Torana up to 300RWHP running 12 easy. VN heads start with 250 300RWHP and go hard. Or you may as well slap it together your self. I would be pist at this.
Dyno’s are a bit misleading maybe 10 or 20 hp but if you have 300 or 400HP it must be in the ballpark. Chassis dyno or eng dyon the air fuel ratio should be set ok still.
Some people use dyno figures to brag and other are disappointed.
Sorry for the disappointment but a little bit of home work and you can achieve this yourself. So an eng builder should do a lot batter than you or me, street manners and power.
If you are going to VN heads you want power, I think you can get better than this pretty easy, SORY.
Those of you old enough might remember the early days of the summernats dyno comp where 500hp at the treads from a supercharged holden was the big stick. In the same era Chris Simpson (I think?) won the aspirated big block comp with 430 odd hp at the tyres.
Mark Hayes valiant took a couple of runs and tweaks to get to 600 hp with the big block blown mopar on methanol.
I simply do not believe a lot of the numbers thrown about, particularly when they involve cars that dont come close to running the MPH to prove their power.
Yours in scepticism.
#53
Posted 04 December 2011 - 09:42 AM
#54
Posted 04 December 2011 - 11:50 AM
XTREME Holden’s volume 11 page 68 VN head 355 LH Torana 10.9 @ 124mph (look very street able)512 HP eng dyno
XTREME Holden’s volume 25 page 28 VN head 355 LH Torana 11.6 @ 119mph (look very street able) 362 RWHP
Do the math’s, Torana 10.9 ¼ = HP ?? must be up there near 500 HP ?
I looked at all these cars parts list and more. All seem to have VN heads T/P or harrip manifold and crane 288 cam is very popular. Put my together and got 404 RWHP.
Even with a smaller cam ryan_525 should get 300/350 WRHP.
If it was mine I would take the manifold off and look at the ports in the heads to see if they have had the bump removed where the push rod go through and especial if he has a T/P manifold they have a very small outlet which must be open up to mach his heads. If the VN heads still have the bump it is the weak link in the chain not much better than red heads.
Edited by ACJ, 04 December 2011 - 11:50 AM.
#55
Posted 04 December 2011 - 06:54 PM
Case 1 has 467 hp by mph, 504 hp by et
Case 2 has 415 hp by mph, 425 hp by et
Case 3 has 366 hp by mph, 353 hp by et
All figures are for approx flywheel horsepower.
I assumed these were not stripped out racecars either with approx race weight with driver of 2750lb.
With the same assumed weight you need 319 flywheel hp to run 11.99
In the slightly lighter LC/LJ (assumed 2640lb) only 307 flywheel hp are required.
So no, you dont need 500hp to run a ten in a square torana.
Lots of happy dynos out there. Makes it hard for the honest guys when their clients say "but my buddys 308 made 500 at the tyres why cant you make mine the same? You must be a spaz."
Of course the client then goes to the crook who is quite happy to take his money and give him a sheet with a bigger number on it.
We call love big numbers. Many of them sadly are not legit.
#56 _injlc304_
Posted 04 December 2011 - 09:33 PM
Scat 355 striker kit
Scat 9000 series crank
Scat I beam conrods
Hypertec pistons
Hasting performance rings
Custom grind hyd cam + hyd lifters (no spec)
roller rockers yella terra
Crow pushrods
Vn heads with mild port polish
Balanced motor
Now also has tp duel low rise
1000 cfm tb
Bosch 044 from surge tank
Twin 2 1/2 exhaust
3.7 diff gears in the 9" with a full spool
Think it's a 2800 stall but yet to take it for a spin to find out.
I'm sure in about 6 months it will get the better of me. What cam and lifters would you suggest? Follow the crowd with a solid 288 with solid lifters? What brands and specs would you recommend?
Edited by ryan_525, 04 December 2011 - 09:36 PM.
#57 _toranarama_
Posted 04 December 2011 - 09:40 PM
So... it's behaving itself then?
#58 _injlc304_
Posted 04 December 2011 - 10:36 PM
#59 _toranarama_
Posted 04 December 2011 - 10:37 PM
#60 _injlc304_
Posted 04 December 2011 - 11:33 PM
#61 _injlc304_
Posted 05 December 2011 - 02:18 PM
#62 _toranarama_
#63 _injlc304_
Posted 05 December 2011 - 02:33 PM
do you have an answer for everything?
So looking at that pretty much gotta pull the motor apart to find out?
Edited by ryan_525, 05 December 2011 - 02:34 PM.
#64 _CHOPPER_
Posted 05 December 2011 - 03:20 PM
He didn't answer that, so obviously no.
If you know what the bore, stroke, crushed head gasket thickness, deck height, piston dome/dish and head cc is, then the motor can stay together. Just having the head CC can give you a close enough reading. The gasket is normally 0.040" and the other numbers shouldn't alter the actual figure by more than +/- 0.25.
#65 _injlc304_
Posted 05 December 2011 - 04:47 PM
Alright so I found some of my engine build info:
Scat I beam conrods
Hypertec pistons
Crow pushrods
Balanced motor
What do you think this would have cost? keep in mind everything in WA has a 599% $$$ increase
#66 _toranarama_
Posted 05 December 2011 - 04:57 PM
No.... but google does
Seriously, I always find it funny that the info's out there but very few have the inclination (or ability) to find it.
sigh...
#67 _injlc304_
Posted 05 December 2011 - 05:00 PM
sigh...
i had actually found a similar calculator but seeing as i know bugger all diamentions i thought i'd ask if there was a easier way. but no
#68
Posted 05 December 2011 - 05:10 PM
#69 _injlc304_
Posted 05 December 2011 - 05:14 PM
What's a google?
brother to yahoo....
cousin to Bing...
#70 _toranarama_
Posted 05 December 2011 - 05:17 PM
#71 _CHOPPER_
Posted 05 December 2011 - 07:19 PM
"1" with a hundred "0"'s after it.What's a google?
#72
Posted 05 December 2011 - 10:03 PM
Sorry but I think you're a bit off on you're weights there, my stripped out hatchback hillclimb car with fibreglass doors, b/bars bonnet,lexan windows no trim , 1 lightweight seat no heaters alloy 9" centre muncie 4speed and a bunch of other weight savings tips the scales at 2760 lb with half a tank a fuel and driver ready to run.that's on very accurate longacre corner weight scales not the local weigh bridge.
Not ragging on ya but the slide rule is only as accurate as the figure you put in.a typical street strip lh lx torry with 9" th350 big wheels and tyres trans coolers, performance fuel systems and all the other crap needed to go hard will tip the scales somewhere between 2975 to 3050lb
#73 _LXSS350_
Posted 06 December 2011 - 01:01 AM
#74
Posted 06 December 2011 - 01:29 PM
#75
Posted 06 December 2011 - 03:16 PM
Edited by myss427, 06 December 2011 - 03:17 PM.
