Hi Guys. My LX runs a 308 with twin 2.5 exhaust and standard fuel tank to which I am trying to fit a holley blue fuel pump. I know it should be mounted as low and as close to the tank as possible, but there is insufficient room.
I may have to resort to mounting it in the boot, but would rather avoid this as the pump is not designed to syphon fuel.
If anyone else has had this problem, where did you fit the pump? Any suggestions?
Holley fuel pump
_ZAK308_
, May 29 2006 12:06 PM
1 reply to this topic
#1 _ZAK308_
Posted 29 May 2006 - 12:06 PM
#2 _Oldn64_
Posted 29 May 2006 - 12:12 PM
Usual place is under the vehicle. if you have a dual exhuast then between the diff and teh front of teh tank is good. It also means it is out of the way and out of site wish is a neat install, not so easy to get too if you need to on the side of the road.. :S
