steel case toyota g/box to red6 inspection plate?
1 reply to this topic
#1 _@milco@_
_@milco@_
Posted 29 May 2006 - 11:50 PM
hi guys,
what inspection plate should i use, i have a steel case toyota box with hydro clutch in my torrie, i got the whole kit from a bloke and he cant find the inspection plate, what one do you guys run?
the motor has a blue fly wheel, i modded a red motor one but the fly wheel hit's it?
are the blue motor inspection plates diffrent to a red motor one? ( i used a manual inspection plate)
help guys this is the lats thing need to get my car roadied!
#2 _Sammy_
_Sammy_
Posted 30 May 2006 - 01:17 PM
i believe the blue motor flywheels are 1inch or so bigger than a red motor one ... so that may be your problem ...
when i got my conversion from Dellow it came with a plastic cover, i've also seen aussie 4 speed ones used with a slight mod to clear the bolts on the celica ..... but if you have the bigger clutch im not sure what your options would be.
maybe try rare spares or someone like that.
