Steering
#1 _Pedrobully_
Posted 30 May 2006 - 07:26 PM
If any one knows where I can get them from please email me.
Iam in darwin N.T. , the only place I have found is American Auto Parts, they have them for $17 ea.
Email [email protected]
#2 _The Baron_
Posted 30 May 2006 - 09:51 PM
They are expensive no matter where you get them.
If you go to the wrecker you may get some good ones.
But be warned, they are a bastard to remove.
Dont forget to fit nylock nuts.
Posted 30 May 2006 - 10:31 PM
#4 _Herne_
Herne
#5 _Oldn64_
Posted 31 May 2006 - 01:39 AM
If you are fitting nylock nuts then why or how do you use cotter pins seeing they are designed for castlated nuts not nylocks...?Rare Spares can supply them too.
Have a look at auto stores or bicycle stores like makka suggested. The other places might be mechanics shops etc.
PS: My parts supplier just through me some... I might have some left over... what size do you need???
#6 _The Baron_
Posted 31 May 2006 - 02:02 PM
Maybe I have the terminology wrong.
The original nuts may have the end deformed to act as an interferance fit on the cotter pin thread.
The nylock nut uses a similair principle where the nylon ring pressed into the end also acts as an interferance fit on the cotter pin thread.
I am just worried that a normal nut may be installed and the unspeakable happens down the track.
I don't know if the push bike cotter pin has the same durability/hardness as the OE.
Bike cotter pin failure = Sore nuts.
Torana steering cotter pin failure = OMFG.
Posted 01 June 2006 - 05:56 AM
#8 _EXLXSL_
Posted 01 June 2006 - 05:48 PM
This is off the Rares Spares site. Looks like a pair is $39.22 and $20.43 each. Do yourself a favour and get the proper pins. Rares also sell the uni-joint.
#9 _The Baron_
Posted 01 June 2006 - 09:30 PM
Are they Nylock nuts on the end ??
Posted 01 June 2006 - 10:09 PM
#11 _Pedrobully_
91107960 COTTER PIN STEER. LINKAGE LC-UC $17.77
#12 _Pedrobully_
Posted 01 June 2006 - 10:10 PM
#13 _The Baron_
Posted 02 June 2006 - 11:15 AM
But torana's are just a hobby to me and I learn something every day.
#14 _Herne_
Posted 02 June 2006 - 12:17 PM
After looking closely at the photo's of the s/h cotter pins available on eBay I know for a fact I would not bother with those and deal directly with Rare Spares or whoever sells brand new ones.
A safety aspect.....
I realise the ebay items were not being overly considered in this thread.
I dont think I would be replacing them with bicycle ones either, albeit a long time ago I seem to recall the bicycle ones actually bending... Something I would not like to have in my steering component.
Herne
#15 _devilsadvocate_
Posted 02 June 2006 - 12:48 PM
Anyway, how to get them out........advice of using a brick is okay for all but the ones down lowest, the engine mount and engine make it physcially impossible to put a brick in here. If you're also in the same predicament as myself(cant get a good swing at that pin (ive got a lpg convertor hanging over mine), join my push to get rares to make the removal tool, I think it would be kinder to the pins too.
Posted 02 June 2006 - 05:28 PM
I thought Castled nuts had split pins?????
Those split pins are also known as cotter pins - hence OLDN's statement above as well.
M@
