I have a 308 in my hatch with the engine number starting with 11WT. The 11 appears to be stamped in a different type to rest of the number. I understand that this designates that it was for a Statesman. Was this stamped at the factory? and what does it really mean. Was there something special done to these engines? I presume that it is a WB block, which means that it is a blue motor, is this right?
11WT Engine Number
_HILLY_
, May 30 2006 07:28 PM
6 replies to this topic
#1 _HILLY_
Posted 30 May 2006 - 07:28 PM
#2 _CHOPPER_
Posted 30 May 2006 - 07:37 PM
The 11 prefix means it was originally made for a Statesman. I don't think there was anything special to these blocks. Others can confirm.
Posted 30 May 2006 - 10:36 PM
i think 11wt is wb stato, nothing special really. afaik blue motor
Posted 31 May 2006 - 06:58 PM
Didn't the 11 mean it was a turbo 400 bolt pattern?
Posted 31 May 2006 - 07:20 PM
I have a aussie pattern 308 stamped with the 11# prefix.
H prefix is from HT,G
QT and 11QT are from HQ,J,X,Z
HT is Torana prefix
HZ is L34 torana
WT in WB range
HT is Torana prefix
HZ is L34 torana
WT in WB range
Posted 31 May 2006 - 10:15 PM
Hi Guys.
The 11 prefix means it was fitted to a Statesman on the assembly line. That's any Statesman from HQ to WB.
HQ 308 were Aussie pattern blocks, & the 11 was also stamped on 253 V8 blocks as 11QR & 202 Statesmans has 11QL. So as you can see it's got nothing to do with Chev 'Turbo' patterned blocks.
Dr Terry.
Dr Terry.
Posted 01 June 2006 - 09:20 PM
Thanks for the info. I have an 11QT numbered block which is a turbo pattern and just assumed thats what it meant.HQ 308 were Aussie pattern blocks, & the 11 was also stamped on 253 V8 blocks as 11QR & 202 Statesmans has 11QL. So as you can see it's got nothing to do with Chev 'Turbo' patterned blocks.
