L31
4 replies to this topic
#1 _keith1962_
_keith1962_
Posted 31 May 2006 - 06:32 PM
Hi to all
i am thinking of placing a th700 in the Torrie but i am a bit
worried that it will not in the transmission tunnel could this be true??????
#2 _Hotrodder_
_Hotrodder_
Posted 01 June 2006 - 12:15 AM
The T700 is about the size of a T400, and that depends on what model vehicle you have whether it will fit or not.
#3 _keith1962_
_keith1962_
Posted 01 June 2006 - 05:43 AM
its a 74' lh/slur
#4 _Sammy_
_Sammy_
Posted 01 June 2006 - 12:46 PM
i have a conversion kit to fit a TH700 behind a holden 6, and i have made up a crossmember for it and everything but it seems to me like the gearbox is not sitting up high enough at the rear compared to what the trimatic was, and this is because it would hit on the floor if it went any higher .... so im not too sure how you'd go .... if it was behind a v8 and if v8's sit more forward than a holden 6 then you might be in luck ...
#5 _keith1962_
_keith1962_
Posted 01 June 2006 - 02:44 PM
Hi Sammy
I think you will find that the transmission tunnel's are
the same in 6's or 8's
cheers Keith
