Manifold dosent line up
Posted 01 June 2006 - 11:59 PM
Cause it dont go as good as it should. Head is good YT- small chamber, 192 bore crow 35802 cam, rollers, graphed elec dizzy etc
Is the manifold holding this thing back
pic lookin in at 5&6
Posted 02 June 2006 - 12:10 AM
New guides, ulp seats, springs & retainers to suit cam......... wtf
Posted 02 June 2006 - 01:05 AM
How does it run? is it bogging down? The overlap in your ports is not a huge issue.
Posted 02 June 2006 - 02:44 PM
I think it cracked about 140HP on the dyno
was expecting it to be a bit quikka
Posted 02 June 2006 - 04:49 PM
You could take the manifold off and mark using the gasket the area that you see causing that lip! THen with a bit of careful die grinding you could blend the area in till you cant see your line anymore! Viola.. Port matched head to manifold!!
That'll be good for it... Maybe too if the manifold is too large you could be loosing your velocity.. One thing that people dont think about is that the air needs to flow in FAST ( thus creating some momentum!) and in a massive port the air flows slowly causing a HEAP of problems!
Do you have any other manifolds you could bolt on to try out before you port match the head to that manifold??
Cheers mate!
#6 _Yella SLuR_
Posted 02 June 2006 - 05:50 PM
Edited by Yella SLuR, 02 June 2006 - 05:50 PM.
Posted 02 June 2006 - 06:03 PM
#8 _Oldn64_
Posted 02 June 2006 - 08:20 PM
Posted 02 June 2006 - 10:47 PM
#10 _Sammy_
Posted 05 June 2006 - 01:46 PM
also i'd have to agree on the port matching, i'd be cleaning up the head so you can't see the port face through that hole .... looks like you will also have to trim the gasket to be a bit bigger aswell.
Posted 05 June 2006 - 07:52 PM
Posted 05 June 2006 - 10:54 PM
Posted 05 June 2006 - 11:06 PM
Is yella terra any help with the pic. If you purchased reciently i don't see why they would not recomend something.
Edited by ALX76, 05 June 2006 - 11:07 PM.
