Heater Box Restoration
27 replies to this topic
#1 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 22 March 2012 - 04:24 PM
I have read through a few posts on this subject but still have some questions.
The foam inside the box to cover the flapper doors and the strip that surrounds the heater core itself are subject to a fair amount of heat.
If I were to use just standard rubber foam I would be worried it would turn to goo with a bit of heat.
Had a chat with the Clark Rubber people and they cant really supply any high temp foam that may suit this purpose.
Any suggestions with what others have successfully used?
Mine is all crumbly and needs some new stuff. I suspect Holden just used rubber foam hence the poor condition.
Also on the subject how do we get the flappers out of the box to work on them, I have mine split but the cranks on the end of the shafts seem to be stuck on. (see picture attached)
Any suggestions on their removal.
Edited by mika03au, 22 March 2012 - 04:27 PM.
#2 hanra
  • 11,025 posts
Posted 22 March 2012 - 05:02 PM
Yeah those arms just pull off, maybe try some mouse milk in there to free em.
#3 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 22 March 2012 - 05:07 PM
they are well stuck, sure dont want to bust them...
#4 hanra
  • 11,025 posts
Posted 22 March 2012 - 05:11 PM
Mouse milk em up! And take plenty of pics once it all splits apart.
#5 hanra
  • 11,025 posts
Posted 22 March 2012 - 05:24 PM
Scroll down here is where I did my heater box:
http://www.gmh-toran...h&fromMainBar=1
#6 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 22 March 2012 - 05:38 PM
Linky no worky Brad.
Michael i asked or local air cond guy for some self adhesive foam, don't know how it will go so can't help you there, will take a pic and post soon.
#7 hanra
  • 11,025 posts
Posted 22 March 2012 - 05:49 PM
Doh!
Down the bottom of this one:
http://www.gmh-toran...0/page__st__350
#8 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 03 April 2012 - 04:00 PM
Cheers Brad & Mort.
So far I have had no luck with any suitable foam, any of the rubber foam melts at 70C and loses it foaminess. (quote from Clark Rubber man)
Brad have you had any heat through yours yet?
I think the heater core would be the same temp as the radiator 90C+ during operation.
Got to be done right as I sure dont want to pull all the dash out again to re do it a few weeks after I get the car on the road...
#9 shadey1963
shadey1963
  • 343 posts
  • Name:Steve
  • Car:5/72 LJ S 2 door Model
Posted 03 April 2012 - 04:35 PM
This company might be able to help. Maybe get a small sample sent out to try. EPDM looks to be good up to 130 C if you check some material tables. Haven't used them but can't hurt.
http://www.gardinera...?prod=RFSR_EPDM
Regards
Steve
#10 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 04 April 2012 - 02:47 PM
Thanks Steve . Will make some enquiries.
#11 hanra
  • 11,025 posts
Posted 06 April 2012 - 07:36 PM
Cheers Brad & Mort.
The original foam that surrounded my heater core was still in good nick, so I re used it. No idea about the specs of the flap foam??? The heater core temp might be similar to the engine temp but the air temp blowing through the heater box wouldn't be as high surely? I'll never use the heater up here anyways, it never gets cold enough up ere.
#12 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 07 April 2012 - 05:34 PM
I get the heater isnt much use up there but am sure airconditioning is a must have....
On your list of inclusions with your Torana?
I wouldnt mind it in mine but the effort seems enormous, whether factory (henstooth), or aftermarket vintage air system. Might just stick with getting the normal bits in order first before tackling that one.
#13 hanra
  • 11,025 posts
Posted 07 April 2012 - 05:58 PM
Yeah my other 60s car isn't used at all for a good 5mths or so over summertime. It's just a sweat box. I'd imagine the Torana will be just as bad.
#14 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 16 April 2012 - 04:17 PM
Quite remarkable, all the guys restoring their cars and no one seems to have been able to source the correct foam for this application.
Guess a lot of guys just leave to old crumbly stuff in place!
My search continues...............................
Edited by mika03au, 16 April 2012 - 04:17 PM.
#15 hanra
  • 11,025 posts
Posted 16 April 2012 - 04:55 PM
I wonder how many people have gone to the effort of re-building the heater box at all???
#16 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 26 April 2012 - 04:28 PM
Im thinking that too Brad....
But I cant help myself now I have pulled it all apart. I just cant put it back together with the old crumbly stuff. I think there is a name for that! Something to do with body parts and retentiveness!
#17 ReplicarSLR
ReplicarSLR
  • 518 posts
  • Car:Not anymore unfortunately
Posted 26 April 2012 - 06:38 PM
I did mine the same way as Brad, used interior rattle can black to colour the foam where you can see it through the vents. I havent had any air through it yet so cannot comment on if the foam is ok. Being in Perth I cannot see myself using the heater much either other than maybe on demist and when the car goes over the pits for rego.
#18 _ass308_
_ass308_
Posted 28 April 2012 - 07:55 AM
i did mine a long time ago.
i dont know what mine were covered in.i gave the flaps to my trimmer,after i pulled the heater box appart,and he covered them.i dont think its anything to special.so far so good no problems at all
its a really hard job :),i pulled 2 boxs apart to make one.
#19 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 28 April 2012 - 02:17 PM
Two boxes? Is that because you broke the first one pulling it apart? Still havent been able to get the crank arms of the flap rods. (see pic in first post) I so dont want to break them. Spraying them hasnt helped as was suggested. The foam they have used looks to be OK, any chance quizzing your trimmer and finding out? (or letting us know his contact and I can ask....)
Edited by mika03au, 28 April 2012 - 02:18 PM.
#20 Mort
Mort
  • 2,760 posts
  • Name:Mort
Posted 28 April 2012 - 05:51 PM
ass308, the grey foam you have on the flaps is the same stuff i have, got it from the local air cond guy, still trying to get some foam for the heater core but.
#21 lx308
lx308
  • 2,843 posts
  • Name:Tony
  • Car:Nuffin. Goin touring.
Posted 29 April 2012 - 05:00 PM
That grey foam looks like what I used also. No dramas in the hatch, yet. I've also just used it on the XU1.
It's about 5mm thick.
Attached File  ImageUploadedByTapatalk1335682793.749323.jpg   113.02K   17 downloads
#22 _ass308_
_ass308_
Posted 30 April 2012 - 08:57 AM
mika03au,i used 2 boxes to make one,because i broke things pulling it apart.. i confess to useing vice grips,to remove the crank arms
ill speak to my trimmer in the next few days,ill let u know what it is.
mort,i didnt use foam for the heater seal,i couldnt find anything decent.i used i strip of aluminium and a couple of grommets.worked out great
#23 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 30 April 2012 - 08:22 PM
thanks heaps, will check the thread to see how you go....
#24 _LXSS350_
_LXSS350_
Posted 07 June 2013 - 10:20 PM
Sorry to drag this up but I am doing up a couple of heater boxes (on the bench) and typical all the foam on the flaps and around the cores are toast. Prefer to find something that will handle the heat as they both are not being built to originality standards. Yes I don't use the heater but still prefer to use something that I feel is far better than the typical foam holden used.
#25 _outer control_
_outer control_
Posted 09 June 2013 - 06:46 AM
A mate used Velcro with success
