253 leaking water into oil
48 replies to this topic
#1 _Kal05_
_Kal05_
Posted 06 April 2012 - 11:49 AM
Hey guys, finally have got my 253 in and was starting to tune it when I noticed milky oil dripping from the front sump seal. Can anyone point me in the right direction as to where I should start looking? Ie how the water may be getting into the oil?
#2 TerrA LX
Posted 06 April 2012 - 12:16 PM
Timing case cover or inlet manifold corrosion or head gasket incorrectly fitted or torqued.
Worse case scenario would be cracked cylinder head or block.
Did you fit the manifold and or timing case cover?
Do you remember any corrosion at the water jackets?
#3 TerrA LX
Posted 06 April 2012 - 12:19 PM
Just double checking, is this milky oil showing on the dip stick?
#4 _Kal05_
_Kal05_
Posted 06 April 2012 - 01:20 PM
Yeah the milky oil is showing on the dipstick, I didn't notice any corrosion around the front cover or manifold, I rebuilt the engine and didn't see anything, all bolts are torqued to spec, and the block looked fine, I'm trying to cover all bases first because I don't wanna pull the engine back out just yet
#5 _Quagmire_
_Quagmire_
Posted 06 April 2012 - 01:30 PM
compression test it...to rule out the head gasket....
Edited by Quagmire, 06 April 2012 - 01:31 PM.
#6 _Kal05_
_Kal05_
Posted 06 April 2012 - 01:43 PM
I'm going to do a pressure test on the radiator to see if manifold is leaking but I would need to take it into a workshop to get a compression test done, just looking for things I can do at home first
#7 _Quagmire_
_Quagmire_
Posted 06 April 2012 - 01:59 PM
cheaper to buy your own...they are like $70 for a decent screw in one
unless your mech works for beer :)
#8 _Kal05_
_Kal05_
Posted 06 April 2012 - 02:06 PM
Really, didn't know u could buy the compression testers that cheap! I'm hoping it's either gasket or head, I'm praying it's not the block..
#9 S pack
  • 15,553 posts
Posted 06 April 2012 - 02:09 PM
Could be leaking where the inlet manifold mates up to the heads.
Did you have the block decked?
Did you have the inlet manifold machined to suit?
#10 _Kal05_
_Kal05_
Posted 06 April 2012 - 02:16 PM
No the block wasn't decked and it's a brand new inlet manifold so I haven't had it machined. Everything seemed to marry up fine when it was installed, had a mechanic build the engine with me
#11 _Quagmire_
_Quagmire_
Posted 06 April 2012 - 02:27 PM
http://www.dealsdire...ion-tester-kit/
weell i was wrong
they are cheaper than beer :)
#12 _Kal05_
_Kal05_
Posted 06 April 2012 - 02:49 PM
Thanks, much cheaper then I'd thought! Any idea what sort of reading I should be getting?
#13 _BLACK LH_
_BLACK LH_
Posted 06 April 2012 - 02:57 PM
depends on the engine specs but as long as they are all about the same give or take, somewhere between 180-200 at a guess
#14 dattoman
  • 16,473 posts
Posted 06 April 2012 - 03:03 PM
Is it possible to fit the head gaskets the wrong way round on these things
I have a vague memory about something like that... but it might be a datto engine
#15 _Kal05_
_Kal05_
Posted 06 April 2012 - 03:10 PM
Well I will try and pick one up tomorrow. See how it goes
#16 Shtstr
Shtstr
    Formerly lcxu105
  • 1,809 posts
  • Name:Mmmmmmm
  • Car:lx hatchback lc gtr
Posted 06 April 2012 - 03:13 PM
sometimes a copm test might not show up a cracked block as a mate of mine found out the hard way and had to pull his engine down twice.
block was cracked just below the lower oil ring line on the bottom of the stroke.
lucky to have an engine left had to get it sleved.
#17 _Kal05_
_Kal05_
Posted 06 April 2012 - 03:33 PM
At the moment I don't even want to think that it's a cracked block! Lol
#18 _outer control_
_outer control_
Posted 06 April 2012 - 03:50 PM
unusual for a problem with 253 blocks to give problem
#19 _Kal05_
_Kal05_
Posted 06 April 2012 - 03:56 PM
Yeah with any luck it's something simple and I don't have to pull the engine apart again!
#20 TerrA LX
Posted 06 April 2012 - 04:29 PM
Where exactly is the leak?
Can you photograph it?
#21 _Kal05_
_Kal05_
Posted 06 April 2012 - 06:38 PM
Yeah I can take photos in the morning, it is leaking from the seal of the sump and front cover
#22 TerrA LX
Posted 06 April 2012 - 07:10 PM
Fair enough, sounds like the leak is totally unrelated to the milky oil but if there is an issue with the timing case I would be looking there first, post the photos up and we can have a look.
#23 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 06 April 2012 - 08:08 PM
A compression test is not necessarily going to show a leak between the coolant and oil holes thru the head.
#24 _Kal05_
_Kal05_
Posted 06 April 2012 - 08:13 PM
No not necessarily but I need to start somewhere, I will do a pressure test on the radiator aswell, other then that it's all guess work
#25 TerrA LX
Posted 06 April 2012 - 08:18 PM
hey mate, tried to call, still got the manifold sitting here for ya.
Sorry for the thread steal.
