Hi i was wondering if anyone can help, i have a Impco gas carby that i want to put on to a 308, i am trying to work out what size carby it is and if anyone knows any one that could service the carby before i put it on the engine or can any carby service shop, service the carby
it has a 4 barrel base and some numbers
C1 - 30
and
425
does that mean it is a 425 cfm carby and would that siut a stardard 308
thanks
Danny
Impco Gas Carby ?
_dannylxss_
, Jun 04 2006 09:54 AM
6 replies to this topic
#1 _dannylxss_
Posted 04 June 2006 - 09:54 AM
Posted 04 June 2006 - 10:13 AM
Yep..Its a 425 CFM Impco...comes in 2 bases that I know of..Holley pattern and Rochester..may be others, I don't know.
#3 _dannylxss_
Posted 04 June 2006 - 05:53 PM
cool thanks,
has anyone used one of these carby's what is the performance like compared with a Quady running straight LPG
#4 _Oldn64_
Posted 05 June 2006 - 12:54 PM
Tund correctly these run really well. On a 308 car you will find that it will start hell better and run nice but run out o puff at about 4800. Keep in mind that the Gas is a 425CFM where as teh quaddy will have been (Smallest Approx) 750CFM.
So yes it will run great and performance is nto too bad, but do not expect to pull the same revs.
#5 _dannylxss_
Posted 05 June 2006 - 02:27 PM
Thanks for your help its just for my daily driver so it sounds like it will do the job,
thanks for all your help
Posted 05 June 2006 - 02:37 PM
I've got a couple..I use 1 one my 208 daily driver..its gr8..bit rich at idle but it starts up fairly quicly in the mornings (10 seconds maybe)
I plan to use 2 on my 234 turbo
#7 _devilsadvocate_
Posted 05 June 2006 - 03:51 PM
Impco 425 is actually rated at 460cfm, see http://www.wps.com/L...-carb-size.html.
Ive actually got a cm125 which is rated at ~200cfm. Which theoretically limits it to 4500rpm on a 202, which isnt a prob.......though it pulls hard to 5500rpm......where the noise stops me going any further.
