Mine did the same thing. Been sitting around for 10 yrs got it out of the shed and it was fine for a while then the same thing started hearing a clunking noise and the bush had just turned to gravel
LH-LX-UC Steering Rack BUSH Collapse
_gam_
, Apr 24 2012 12:18 PM
Steering Rack Bush Fragmented
29 replies to this topic
#26
_Mitch_
Posted 04 August 2015 - 07:48 PM
#27
Posted 04 July 2016 - 02:09 PM
Has anyone changed this bushing themselves ?
I have just found the same scenario,had a clunking noise from the steering rack and when I pulled back the left hand boot, fragments of the bush in the oil ,along with some rather large chunks.
Wlll remove the rack and hopefully someone can steer me in the right direction.
(Pardon the pun ??)
(Pardon the pun ??)
#28
Posted 06 July 2016 - 04:31 PM
Well found one for myself, got it from Bursons and cost me $17, fitted up and now to reassemble !!
#29
Posted 18 July 2016 - 07:59 PM
^ don't forget to get the preset load on the ball and socket to a non binding or too loose setting once the lock nut is done up to fit the tap in lock pin that hold the 2 together , it seems to loosen up a bit when the lock nut is nipped up?
#30
Posted 18 July 2016 - 09:14 PM
Yep..thanks..I did that , yet to drive it yet as doing a few other things as well.
I also Changed the tie rod ends whilst I was at it.
