heater setup
makka
, Jun 05 2006 03:21 PM
9 replies to this topic
Posted 05 June 2006 - 03:21 PM
I have seen 2 different heater setups on LC-J's one with the big fibreglass heater box and one with a small folded steel one like on red6's LC.
does anyone have other pictures/information on the setup like red6's?
I like the look of it better and I might do dads LC like that because it has nothing at the moment.
cheers,
Makka
cheers,
Makka
#2 _Oldn64_
Posted 05 June 2006 - 03:32 PM
The folded ones are usually no fan assist heaters. If you wish to clear windscreens and generally pump warm air on a still morning when at lights I would get a fan assisted one.
Posted 05 June 2006 - 03:49 PM
I thought it could have been like that, but I cant even see any haeter hoses going in there! i was thinking about putting 2 comuter fans in there, its only gonna be dads fun car, so it wont matter if it doesnt really work all that well
Posted 05 June 2006 - 07:00 PM
Hi Guys.
The folded steel panel is from a '69 LC Torana. It's just a panel fitted to direct fresh air into the cabin when NO HEATER is fitted.
These early pre-ADR cars had no heater unless they were an SL or GTR.
There is another type of heater for pre-ADR cars without a fan, but these still have 2 water hoses.
AFAIK it is illegal to remove the motorised heater/demister out of a Torana made after 1/70.
Dr Terry.
Dr Terry.
Posted 07 June 2006 - 12:07 PM
I think you're right, Doc. I'm pretty sur it's ADR 15 which specifies that warm air must be directable onto the windscreen to demist it.
From the DOTARS website -
ADR 15 - Demisting of Windscreen
The function of this Australian Design Rule is to specify requirements for standards for equipment to maintain the windscreen clear of `Mist` so that driver's `Forward` vision is not obscured.
Posted 07 June 2006 - 01:39 PM
cheers guys, I reckon I can rig up a heater and fan into one of them.
makka
makka
#7 _munro_
Posted 07 June 2006 - 08:11 PM
my '70 Lc had no heater only vent when i bought it
since then i've aquired both types
i recon the non fan unit would be perfect for that v8 conversion
cheers tom
cheers tom
#8 _73LJWhiteSL_
Posted 07 June 2006 - 08:41 PM
I believe Shevster has the heater like the one above with a heater core in it.
My SL and S (73 cars) both have the full box, as does my mates 70 LC S.
Steve
Steve
Posted 08 June 2006 - 10:38 AM
funny what you can find on these forums when you start looking...my Lc 2 door as pictured has no heater at all which is pretty annoying considering it hit 1 degree here last night. My other car an Lc 4 door had the samee set up but had a heater core mounted behind the box/panel you are talking about with two houses leading into/out of it and a switch in the hose going into the core so you could stop the flow and restrict the flow, not an ideal set up but it did the job provided you were moving.
#10 _troy_
Posted 08 June 2006 - 11:24 AM
I ripped my heater box and demister set up out of my torana and binned it while rebuilding it i went to the 12 volt shop and got 2 plug in the cigarette lighter hair dryers hooked em up to a switch and she rolled over the pits they said it didnt need a demister build date 10/1970 but they never new about the hair dryers
