Noise & Vibration
#1 _73LJWhiteSL_
Posted 05 June 2006 - 07:34 PM
Been having some problems with the LJ. Its a 173, Commodore cable clutch, M20
and 3.36 Banjo.
Basicaly if have been hearing a metal screaching noise, similar to when you 'turn' a piece of metal up in a lathe, that metal on metal sound, and vibrations.
Last nite i replace the oil in the gearbox and there was no metal filings in the oil i drained.
Anyone got some suggestions?
Steve
Posted 05 June 2006 - 07:43 PM
#3 _Herne_
Posted 05 June 2006 - 07:59 PM
Herne
#4 _73LJWhiteSL_
Posted 05 June 2006 - 08:17 PM
Steve
#5 _Herne_
Posted 05 June 2006 - 08:20 PM
Herne
Posted 05 June 2006 - 08:26 PM
teltail signs will be a shiny ring at the contact point.
#7 _73LJWhiteSL_
Posted 05 June 2006 - 10:20 PM
Steve
Posted 07 June 2006 - 12:07 AM
Posted 07 June 2006 - 03:02 PM
#10 _73LJWhiteSL_
Posted 07 June 2006 - 08:59 PM
The noise doesn't sound like a fan belt squealing, but i will have a look at that when i get the car running again.
I hope its not the water pump or alternator. Both have been replaced in the last 6 months, the water pump a genuine Holden part, and the alternator a recoed 50 amper from a mate of dads.
I discovered last nite that there was some vertical movement in the tail shaft uni joints, both of them, so i have given the tail shaft to a mate and two new uni joints to replace the installed uni joints.
Once i get the tail shaft back i am going to check all the bolts on the diff (I did change the centre 6 months ago) and the bolts on the gearbox, bell housing and cross member ( I replaced the rear gearbox mount about 2 months ago). The clutch still has plenty of meat on it (about 10mm so 5mm + 5mm) and the flywheel and all clutch all seems to be bolted together fine. As mentioned above i did an oil change on the gearbox on sunday nite, so from what i have told you above if the noise isn't the unis destroying themselves from lack of lubrication, my next assumption would be the thrust bearing or possibly engine mounts.
I checked the tailshaft for signs of rubbing and there was no shiny rings on the tailshaft.
Thanks again for the suggestions peoples. I love this forum
Steve
#11 _devilsadvocate_
Posted 07 June 2006 - 09:52 PM
Posted 08 June 2006 - 12:41 AM
That thing better be OK for Winton
Edited by rodomo, 08 June 2006 - 12:42 AM.
#13 _73LJWhiteSL_
Posted 08 June 2006 - 06:47 PM
Rodomo Brake linings are fine, it doesn't quite sound like a metal on metal from brake pads being worn out. The pads on the front weren't replaced that long ago.
I am planning on getting to Winton...
Steve
#14 _73LJWhiteSL_
Posted 10 June 2006 - 11:44 AM
Thanks for the suggestions guys. I stuck the tailshaft back in last nite with the new uni joints in it, and yes they have been pumped with grease this time and took it for a spin, down the freeway and everything, no noise or vibration.
Well I learned something now... make sure you pump grease into your uni joints.
Thanks again people.
Steve
#15 _Herne_
Posted 10 June 2006 - 12:18 PM
It was the vibration that clued me onto the uni joints, been there and experienced that before, I am sure many have!
Good luck and happy, safe motoring.
Herne
Posted 10 June 2006 - 03:25 PM
#17 _devilsadvocate_
Posted 10 June 2006 - 04:13 PM
Glad youve got it sorted Steve.I don't have a fan guard devils, i will check to see if the motor is pulling to one side when reving once i get the tail shaft back in.
nb: the motor will only visible tilt to the right(normal) when you suddenly increase the revs....when in neutral......or when in gear when you give it more gas.
#18 _73LJWhiteSL_
Posted 11 June 2006 - 04:54 PM
Yeah Herne I just wasn't prepared to accept this suggestion straight up since it was only 12,000 miles since i replaced the uni joints... of course i never pumped them with grease so it all makes sense now.
I still haven't checked that yet but yes i know its when you suddenly increase revs in neutral. Its on the todo list.
Thanks again everyone.
Steve
Edited by 73LJWhiteSL, 11 June 2006 - 04:55 PM.
