acrylic paint problem
#1 _pocock_
Posted 15 May 2012 - 12:35 PM
thought it might it may have been bad prep because as i say they were at first only in the crevices
but i sand them out and then in 2 or 3 weeks they might pop up some where else i am thinking its the old paint i have painted over any ideas on how to tackle this problem and what might be the cause
pocock
#2 _Quagmire_
Posted 15 May 2012 - 01:18 PM
bad paint normally "spider webs"
in my experience
in all reality you will have to strip it back....apply a sealer/2 pac primer and go again
Posted 15 May 2012 - 01:24 PM
1. Humidity blisters: When it was painted, there was moisture coming through the gun or it was too humid the day it was painted.
2. Prep not good enough
I would be going more towards 1.
Glenn
#4 _pocock_
Posted 15 May 2012 - 01:30 PM
as an old fella advised me many years ago 2 coats rubbed it back with 600 the next day then left it a week or two
then 2 more coats rubbed it back the next day and left it another week or two and repeat the process till you get 6 coats on and 4 of clear lets it dry properly and lets the solvent escape between coats its always worked this is a full respray so big job taking it back to bare metal and starting over again
pocock
#5 _Quagmire_
Posted 15 May 2012 - 01:33 PM
prime/seal sand and top coat
pita but it's the only way i can see you stopping it
#6 _pocock_
Posted 15 May 2012 - 01:36 PM
on spray days , usually humidity blisters in my expierence come up in small patches heaps of them and they come an d go these little buggers are single or in pairs
#7 _pocock_
Posted 15 May 2012 - 01:48 PM
what will stop it coming through the new pimer and top coat its a tricky one in hind sight it should of been striped back to bare metal
epoxy primed, repairs done primed in 2k and top coated because you never know what paints underneath if you havnt done it yourself but as i say to do that now is a big job ,time consuming and also costly
Posted 15 May 2012 - 03:53 PM
#9 _pocock_
Posted 15 May 2012 - 05:01 PM
but it continues to happen there very hard to see at times as the colour is off white so i dont think they would show up very well in a photo
pocock
#10 _Bomber Watson_
Posted 15 May 2012 - 06:42 PM
What kind of filters are they?
What size is the compressor?
How old is the air line"
How long is the air line?
What brand and product line primer did you use?
What brand and product line Thinner did you use in the primer?
What brand and product line filler did you use?
Where in relation to the bare metal and the primer did you use filler, if any?
What brand and product line top coat did you use??
What brand and product line thinner did you use in the top coat?
Where did you get the mixing ratio's for all the above?
What do you use to clean the gun out?
Where was the vehicle stored while it was "curing" for two weeks as you mention?
How did you prep the old paint??
Did you do any tests to work out what the old paint was??
What condition was the old paint in?
Got a few more questions, but answers to the above will do for now.
#11 _nial8r_
Posted 15 May 2012 - 08:08 PM
when i do a lick & stick ( Acylic ) i just give the old shyt a good rub with 240wet, wash it down, let it dry or blow it down with the compressor, presol, high fill primer, 1st a dust over then start laying it down a bit heavier till i have about 4 coats one after the other and make sure the last coat is nice and wet. leave it for a day or two and then block it down with 800wet wash al the sludge off getit dried off, throw 2 more coat of H/F over it let it go off then give it a light dry rub with 600 in a circular motion, prepsol, throw the base on and then then get my clear ready while the base flashes off and on it goes, about 4-5 good wet coats then i let it sit for a good week or two then chop it with 1200 wet to get any peal out of it, buff and polish and its like glass and never had a problem.
yes i have had about 8 Rums my number one guess would be moisture but what do i know im just a tin tapper
Posted 15 May 2012 - 10:19 PM
Well Pocock, if DJ can't find you an answer then it might be just as easy to start from scratch and bare metal it.
#13 _pocock_
Posted 15 May 2012 - 10:40 PM
then painted as decribed earlier paint used was protec primer filler and concept paint and thinners for top coat the car was top coated back in febuary and has been left sit to cure and has not ben cut and polished as yet, all air lines are 12 months old
compressor ingersoll rand 60 litre tank 1st trap 1 metre from compressor 2nd trap 4 mtrs from compressor in line done many cars
never had a problem before
pocock
Posted 16 May 2012 - 06:00 AM
Maybe someone has used silicone products on the car which is working its way through the new paint?
#15 _pocock_
Posted 16 May 2012 - 10:05 AM
pocock
#16 _Bomber Watson_
Posted 16 May 2012 - 06:04 PM
Before putting sandpaper anywhere near anything i wash it down thoroughly with dishwashing liquid then prepsol it.
Why did you mix brands primer and top coat? And why oh why in gods name did you use anything from Concept??
#17 _pocock_
Posted 16 May 2012 - 10:41 PM
pocock
#18 _Yella Fella_
Posted 17 May 2012 - 03:37 AM
Edited by Yella Fella, 17 May 2012 - 03:37 AM.
#19 _Quagmire_
Posted 17 May 2012 - 10:08 AM
make sure all your car wash/wax/cleaning stuff
and silicone sprays are at least 10 metres away from the shed when spraying
and wash the floor really well too
Posted 17 May 2012 - 11:32 AM
#21 _pocock_
Posted 17 May 2012 - 12:58 PM
just having a think about what course of action to take .
thanks
pocock
#22
Posted 17 May 2012 - 08:37 PM
#23 _pocock_
Posted 17 May 2012 - 10:36 PM
#24 _Yella Fella_
Posted 17 May 2012 - 10:54 PM
What grade paper did you prepare the surface with again? May be a an issue with the paint not keying properly with the base coat. Maybe didn't sand enough, and the paint is not bonding properly.
I've never had anything like that. Sometimes I wish I could have some issues to solve.
#25 _pocock_
Posted 18 May 2012 - 12:21 PM
of problem with the old paint , should of been removed in hindsight so now it is either leave it and see what happens or take it all off and start again.? thats the question will these little bubbles get bigger and cause the paint to lift off over a time once it gets out in the queensland weather i know one thing if i do decide to take it all off i will be using epoxy primer over the bare metal , then apply iso free 2k high build primer then the lacqurer top coat should give agood solid foundation so i have been told
pocock
